cooling fan problem
Rep Power: 0 cooling fan problem
Hi, today when I got off highway, on city streets, the temperature needle raised close to the red. When the car was moving, it started coming down. When I stopped the car and checked the fan, it wasn't running.
I jumped the 2 wires out of the temperature sensor on the thermostat housing, the fan ran.
Does it mean I have a bad coolant temperature sensor? Or the head gasket is blown that caused the high temperature?
Thanks.
2004 EX Coupe auto transmission
Thanks.
Re: cooling fan problem
Low coolant level can hinder fan operation and cause the engine to run hot.
And the fan temp sensor is not located in the engine dump stream (top hose), it's located in the radiator lower hose stream. That means the liquid exiting the radiator would have to be very high in order to run the fans.
See if the radiator and cooling system is low on coolant.
See if the reservoir has barfed liquid out and made a mess.
Refill and burp the air out, see if that makes the overheat problem goes away for the moment.
I'll run with the standard 'blown head gasket' guess.
IMO The only data he could really make use of is the engine coolant temp (ECT), which should confirm the gauge on the dash probably isn't lying.
Rep Power: 0 Re: cooling fan problem
Thanks Ezone and Poopies.
I touched both hoses and it seemed they were both hot to the touch. I thought thermostat was working.
I added some coolant before the trip so I think coolant level was OK.
Yes, it did barf a small amount of liquid.
I will do that and test it.
I heard of a "balloon" test for head gasket. I will read the forum and figure out what the "standard" test is. I thought of buying the combustion test kit.
Today, I plan to go to Autozone and get a new thermostat. Yeah I know it's bad to throw parts on it before figuring out what's really going on. But the wife is a typical blonde and she drives it when I am at work. I am sure when it happens she has no clue and the only way to stop her is a full blown engine
I planned to do tax today, hope it doesn't take long to put the new sensor on.
Several years ago, I could pull an ear of corn out of the pan of nearly boiling water without pain. What was the real actual temp of the water? (The one time I stuck a digital thermometer in the water it read 206*F.)
Gotta KNOW for certain where it's at NOW that there is a problem.
Coolant gets pushed out slowly during the course of the trip. If the trip is long enough, quite a bit of coolant can be pushed out.
(Unless the reservoir was overfilled to begin with, then all bets are off.)
If refilling keeps the temperature gauge in the right place, the thermostat is not the likely issue.
Note: There can be 'air' pockets trapped in the high spots of the system which can make the radiator APPEAR completely full as you loosen the cap, when in reality the system is low.
Check out this thread: Overheating common causes - reference
Too unreliable for me to use in the shop, I jump directly to the test that proves it for me every time.
NOTE: This is a pattern failure on this engine. There might be any of a dozen ways a typical head gasket can fail, but there is one common way this particular engine does it. I test for that failure first because it is most likely to give me the results I am looking for.
Use a factory thermostat........ and it might be easier to change it while the head is off.
It looks like the sensor fails to turn the fan on. But I am not sure if that's the real cause of the high temperature. 3 likely causes:
- temperature sensor failure, fan not on
- air pocket in cooling system, need refill/flush it out
- head gasket leak
The 4th, I hope it didn't happen, is the wife baked it so hot the engine block warped beyond repair and I have to get a new engine.
LOOKS like.
But does it?
The liquid exiting the bottom of the radiator would have to be 203*F or higher before the fan is switched on. ANY breeze blowing through the radiator could keep the liquid cooled enough to not need the fan operating.
Jumping the wires at the temp sensor only verified everything EXCEPT the sensor can work (fans, relays, etc.). It did not test the sensor itself at all.
Remove it, connect an ohm meter to it, and drop it in boiling water?
Hey Ezone, I tried to refill/flush the coolant first and it seems to fix the problem. I put the car on 2 jack stands and refilled it over 30 minutes with engine running and full heat. I saw some small bubbles at the radiator opening. When I increased the RPM and watched the bubbles, some bigger(~1/2" in diameter). Everytime when I increased RPM, big bubbles came out. After I repeated it about 10 times, it's still there so I gave up. I refilled coolant whenever I saw the level was below the opening. Maybe I have a leak head gasket since the bubbles never stopped.
After the refill, I drove it to highway and back to town. No overheating occurred.
Honda user manual says don't fill coolant at the radiator opening. I think it's a mistake? That's what I did, only fill it in the reservoir. I think the air in the radiator causes air pockets in the engine. From now on, I will fill coolant in radiator and reservoir.
Thanks for your help, Ezone.
Your overheat complaint was the result of low coolant level.....which is usually caused by a blown head gasket.
For a new car buyer in an ideal world, with a meticulously maintained car, that might work. It stops working as soon as the radiator is low.
The radiator MUST be filled first.
Make sure you check out this thread: Overheating common causes - reference
I checked my user manual. Actually, it doesn't say we can't add coolant into the radiator. It's the piece of white paper under the hood labeled "Emission Control System" that says:
"CHECK OR ADD THE COOLANT AT THE RESERVE TANK, NOT THE RADIATOR"
It's likely my HG is blown because when the engine is in idle, I didn't see bubbles. But when I gave more gas, I always saw ~1/2" in diameter bubbles.
amrhamed
08-31-2015 07:47 PM
Bruce.Ringler
06-18-2015 08:12 AM
dinsum
05-28-2015 09:30 PM
hokiedad4
05-03-2015 10:06 PM
