intake diy help
the Destroyer
intake diy help
wanna install an SRI intake myself on my 03 DX, anybody have a list of socket sizes/other tools i would need? just want to make sure i have everything before i start and find myself f**ked partway through.
Super Moderator
Re: intake diy help
Dude, the whole thing is RIDICULOUSLY easy. I was new to it too, so I took my time, did the work in a parking lot, cleaned my throttle plate, threw in a grounding upgrade and was still done in under two hours. There is NOTHING you will do that can't be reversed, as long as you don't break anything. You will probably need a 10mm socket (if I'm not mistaken) and probably a flat-head screwdriver for the fasteners on your new intake. Which SRI are you getting?
Received 1,146 Likes
Rep Power: 485 Re: intake diy help
Flat head screw driver and a 10mm socket, I believe is all you need. A 12" extension will make your life easier, as well. I don't think you need a 12mm socket, but it wouldn't hurt to have one on hand.
It wouldn't hurt to have some small sockets for hose clamps instead of a flathead screwdiver
edit: I can't read, and poopies got it all covered. Just FYI, you can virtually disassemble a Civic with not much more than 10, 12, 17, and 19mm sockets
HAHAHAHA
I immediately imagined a freakin baby in diapers nomming on some sockets.. Then started to question your position as a parent. Nice save. Much more entertaining than a ninja edit.
Kenny the Ricer
Re: intake diy help
Definitely more entertaining than a ninja edit.
Just Phillips and/or flathead screwdriver (Depending on what type your hose clamps are)
a 8mm, 10mm and 12mm socket is enough. (8mm in case you want to use that for the hose clamps)
Might help to have an extension, but not necessary.
If you can remove a wheel and install a spare, you can install a SRI.
Received 1,440 Likes
the Destroyer
Re: intake diy help
just a cheap ebay sri atm, not nice being flat broke all the time. planning on picking up either a K&N + head shield or an AEM next week.
only trouble i had when installing, the kit didn't come with anything to hold the o2 sensor in place!
Inrake air temp sensor. Well, I'm assuming that's what you meant. There aren't o2 sensors on the intake. Drill a hole in the pipe and call it a day. Also, you can eBay pipe it all day long, just slap a good filter on it. Back when everyone realized the d17 doesn't respond to bolt on mods very much, lotsa people started recommending a cheapo eBay pipe and slapping an AEM dry flow filter on it.
ThatGuy913
11-09-2015 06:31 AM
juicetayne
09-30-2015 11:02 AM
thaler4cuse
09-07-2015 08:25 PM
