Car is not acting the same after new trans.
Rep Power: 0 Car is not acting the same after new trans.
So This weekend I replaced my 01' trans with an 05' trans and got a new OEM clutch. Second gear works! The problem is now on the high way it makes a sound like something isn't spinning right. It also boggs a lot when shifting into first and second. Idk if that's because it's a different clutch and I'm not use to it or what. But it now sounds like garbage compared to before the trans install. Please help!
Rep Power: 0 Re: Car is not acting the same after new trans.
Could be the input shaft bearing, they go bad on a lot of 7th gens. Do you hear the sound when the car is stationary on only when driving? Here is a great page on the forum to help diagnose tranny noises. https://www.civicforums.com/forums/1...save-some.html
usually with a new clutch install . one must adjust the pedal to change the engagement point. it might feel like your going to stall . for instance with a stock clutch people usually let out the clutch without any gas, it take off fine. with a new clutch sometimes people will have to blip the gas a bit while letting out the clutch to help with stalling. im sure its normal whats happening . just have to re adjust to the new pedal feel. have to change your driving technique. good luck
oneheadlight
04-29-2015 11:30 PM
tylerginevan
04-27-2015 12:29 PM
cdt12271
04-23-2015 11:36 AM
