2002 honda civic sedan
Rep Power: 0 2002 honda civic sedan
Hi. My es1 have a problem. The problem starts when i put a aftermarket intake, the idle goes crazy and my rpm can't go on the redline. Then i removed the intake a couple weeks ago and then engine gets weaker. After i put the intake my car can only rev at 6k rpm and now it can only rev at 3k. When im reving it up its like the engine is drowning. The fastest speed it can go now is 60 kph. It takes 2 mins to go 60 kph. There is no engine light on the cluster. What do you guys think about the problem of my car?
Super Moderator
Re: 2002 honda civic sedan
Did you clean out your throttle plate?
What brand is the intake?
Did you reattach all the sensors correctly?
Did you reattach the PCV (positive crankshaft ventilation) hose correctly? It isn't pinched, is it?
How about the filter? If it's supposed to be oiled, did you over-oil it?
***Post a picture of your setup.***
Rep Power: 0 Re: 2002 honda civic sedan
jessicakaybby
04-20-2015 12:11 PM
aus10
04-13-2015 09:26 PM
Lightman
11-10-2001 06:44 PM
