Sponsored by:
Sponsored by: DashLynx
Question on crankshaft oil seal
Old 07-08-2013
xeno-a's Avatar
xeno-a is an unknown quantity at this point
when i read the haynes repair manual, it said lubricate the seal with engine oil or grease. I want to know is it ok to use the regular engine oil (5w-20).
and if i use grease, what kinds of grease ?
thank you !
xeno-a is offline
Old 07-08-2013
johndeerebones's Avatar
johndeerebones is a jewel in the roughjohndeerebones is a jewel in the roughjohndeerebones is a jewel in the rough
Re: Question on crankshaft oil seal
The main thing is not dry. The idea is to lube it so it's not dry until oil gets to it. What is used is not the more important thing here. I use grease on seals just because it is heavier, but any lube is better than none.
Why are you working on it? A large leak is possibly the pump itself. There is a high pressure oring behind the seal too.
johndeerebones is offline
Old 07-08-2013
Factory seals often come already greased. If not, I prefer to lube with whatever fluid it will spend the rest of its life running in.
ezone is offline
LionSpratt
01-29-2017 11:07 PM
RIPSAW
11-06-2015 04:36 AM
Vaguexo
06-13-2015 04:11 AM
leon1
04-28-2015 07:32 PM
viper775
12-09-2001 10:52 PM
Quick Reply: Question on crankshaft oil seal
