Trouble with reverse on manual trany
03 Civic EX
Rep Power: 0 Trouble with reverse on manual trany
I've had this problem for a while but now it's basically unbearable. Every gear is perfect except (R)everse. I've read a couple threads on putting the car in first then shifting to reverse, that doesn't seem to help at all. I checked the brake fluid which was full...unless I'm mistaken we have hydraulic slave cylinder? I've never had an issue with just reverse before in any car so my thoughts are either the trany, the clutch, or the slave? Any help would be greatly appreciated.
03 Civic EX
Rep Power: 0 Re: Trouble with reverse on manual trany
Yes I've been trying the double clutch, doesn't really seem to be affecting it much. It almost feels like there needs to be another half inch of throw to get it to reverse that just isn't there.
skate or die
Rep Power: 255 Re: Trouble with reverse on manual trany
Yeah this problem is notorious. Honda makes good engines, not transmissions.
My reverse sometimes does not catch sometimes, so I put it into reverse once, then neutral, then reverse again to make sure it is engaged. You can hear it engaging properly.
Rep Power: 165 Re: Trouble with reverse on manual trany
Reverse gear doesn't have any synchros. Are you trying to shift into reverse while moving backwards already? Either shift in while standing perfectly still or else you would have to rev match perfectly. Otherwise I've found that it takes a little bit more force to get into reverse than the other gears. Once in a while you can feel it not going into gear all the way (Like 1/20 of the time) so just take it out and push it back in. Other than that-not much you can do. You could try flashing the manual transmission fluid
Super Moderator
I changed the MTF in mine a few weeks ago and it shifted into reverse like melted butter... for the rest of that day. The reverse issue is probably just our cross to bear as Civic owners. ;-)
I have an 01' and it also doesn't shift into reverse very well. Like the other person said you can hear it when it finally goes in. Usually have to shift from second to reverse a couple of times. UGH.
05-04-2016 07:14 AM
estes53
07-20-2015 10:43 PM
