Help replace factory shift knob
Old 04-14-2013
ProAc_Fan's Avatar
ProAc_Fan is an unknown quantity at this point
Help replace factory shift ****
I've got a Momo Superanitomico shift **** I found laying around the garage. It has a little rubber insert inside already. How do I go about using it to replace the stock shifter ****? I tried to put it on already but that was a no go.
TIA
Mike
ProAc_Fan is offline
Old 04-14-2013
Received 1,143 Likes on 798 Posts
Re: Help replace factory shift ****
What did you have issues with?
xRiCeBoYx is online now
Old 04-14-2013
ProAc_Fan's Avatar
The issue is the **** won't even go on the threaded shaft. There's a small rubber insert inside the momo shift **** already. I'm thinking that insert may need to come out. I see a small hole on the base of the **** which would take a small set screw that I don't have. I simply found this **** laying around the garage. I'm hoping to thread the new **** onto the shifter but I'm not 100% sure if that's the proper plan.
Mike
Old 04-14-2013
Whachya lookin at?
BlueEM2's Avatar
Aftermarket ***** generally aren't the thread on type. You will need to find the set screw or a screw the same size (those things are small) to make it stop spinning on the shaft. I don't see any other way to install it honestly.
BlueEM2 is offline
Old 04-14-2013
lowlife9's Avatar
lowlife9 is offline
Old 04-15-2013
ProAc_Fan's Avatar
Update....got the momo shift **** installed. Kept the factory boot and it looks and feels pretty nice. Not sure I would have spent the cash if I had to buy it but since it was a freebie I'm quite happy about it. Now to install the free strut brace and free cold air intake.
Mike
cruisers10
05-12-2015 10:46 PM
What_It_Do
05-10-2015 05:31 PM
AFlyer
12-22-2001 01:18 PM
vexxed82
12-19-2001 09:26 AM
StLVtec
11-14-2001 09:22 PM
Quick Reply: Help replace factory shift knob
