2001 Honda EX Junkyard D17 Swap
Rep Power: 0 2001 Honda EX Junkyard D17 Swap
I have a 2001 Honda Civic EX which had the D17A2 Engine with a rod knock. So me and a buddy grabbed a Engine from the local junkyard. It happened to be the D17A1 Block from a LX. After reading a bunch of the forums it appeared that as long as we kept the Head from my EX (VTec) and since my ECU is a EX (VTec) it would work. So we got a D17A1 Block with my D17A2 Head back in the car, everything is hooked back up. Were getting the engine to crank but not start. We checked fuel lines and fuel is pumping to it. When we try to start it after theres a bunch of clicking on the passenger side which i assume is probably the computer. We tried pulling the ECU fuse to reset the computer along with most fuses under the hood. Before the swap the car started fine just had a terrible knock. Any ideas?
Re: 2001 Honda EX Junkyard D17 Swap
Yea check for spark to start...but clicking from the passenger side is likely from the main relay, meaning it's either fried, or there's a bad ground somewhere, or both. Check all of the grounds in the engine bay and make sure they are all good, then check the main relay next to the ecu behind the glove box and make sure it is good, if all the grounds seem fine.
Rep Power: 0 Re: 2001 Honda EX Junkyard D17 Swap
I did a compression test which tested to 180 psi so i think thats pretty good
i got a Spark tester and tested the coils and got no spark which i mean we all kinda assumed that here that it was a spark issue but i tried some different coils still no spark
Grounds look good
Grounds look good
LionSpratt
01-29-2017 11:07 PM
Bartkat
20
02-19-2002 01:29 PM
