Sponsored by:
Sponsored by: DashLynx
Cluster removal
Old 01-30-2013
stock's Avatar
stock is on a distinguished road
Cluster removal
I need to pull the cluster to replace the bulbs.
I'm having a hard time pulling the bezel trim off to get at the cluster. I read that the upper steering column cover needs to be removed. Is removal required?
Also do I need the special KTC trim tool?
Removal/Installation Special Tools Required KTC trim tool set SOJATP2014 NOTE: Use the appropriate tool from the KTC trim tool set to avoid damage when prying components. Take care not to scratch the dashboard and related parts. Tilt the steering column down. Remove the steering column upper cover. Remove the instrument panel (A). Remove the screws (B). Gently pull out along the bottom to release the clips (C) and hooks (D). Gently pull out the upper portion of the panel. Install the panel in the reverse order of removal, and push the clips into place securely.
stock is offline
Old 01-30-2013
Received 1,148 Likes on 802 Posts
Re: Cluster removal
O_o
Wanna know how I do it?
Step 1: Adjust steering wheel to lowest position
Step 2: Remove 2 screws holding in bezel
Step 3: Finagle the damn thing off. It's fairly pliable; you'll know if you're gonna break it
Step 4: Remove 2(?) screws holding cluster on
Step 5: Finagle the cluster out, removing the green and blue plugs as you can
Step 7: ??
Step 8: Profit
xRiCeBoYx is online now
Old 01-31-2013
stock's Avatar
Re: Cluster removal
O_o
When you finagle it, do you pull the bottom of the bezel straight out or up and out. I understand there are clips holding the bottom of the bezel in place.
The upper steering column cover appears to be in the way. If I remove the upper steering columnn cover, will I have problems getting it back on? I read somewhere that the upper steering column cover has tabs that break if you try to remove it. Is it true?
The backlight for the numbers on the speedo are out so I can't see how fast I'm going at night. Will regular #74 bulbs fit into the socket or do I have to file them down and cram them into the sockets. I don't feel like paying Honda $10 for each bulb.
stock is offline
fatih717171
07-25-2016 06:22 PM
greenbackz
07-30-2015 12:04 AM
ZILLA
Air Conditioning
07-11-2015 08:35 PM
ballmich
07-09-2015 11:59 AM
fatih717171
07-08-2015 12:14 AM
Quick Reply: Cluster removal
