New 2005 Civic Owner here! Stop in and school me a little!
#61
Received 1,440 Likes
Rep Power: 338 Re: New 2005 Civic Owner here! Stop in and school me a little!
Lol, I think the Toyota 22RE was the nastiest engine I've dealt with. The timing chain could break the plastic guides and then chew through the water jacket milkshaking the oil.
Honda actually has a good design there if it was done on purpose. No milkshaking saves a lot of engine damage and it's easy to see your reservoir puking out fluid.
My '78 Civic used to run just fine until I shut it off and about 60 seconds later it would violently blow about a liter of coolant out the reservoir. I used to try and get as far away from it as I could before it puked so people didn't realize it was my car, lol
I prefer to do the gasket than the whole engine...
#62
strange... my previous post seem to have been lost...
not sure of the prices, sicne i did the job in my garage...
concerning what you could do now, there's one good mod since you have an EX: Crower stage 1 camshaft.
see main thread here:
https://www.civicforums.com/forums/7...ge-1-cams.html
valve lash adjustments can be found in here:
https://www.civicforums.com/forums/7...-question.html
#63
Just looking to save some MPG!
#64
Parts!! Waiting on the head gasket set to come in and the rad hoses.
Thought to my self... I might as well grab some cabin air filters while I'm here.. good thing I did!
#65
ezone: Question for you. I'm running my scan tool in the car to monitor the engine temps while I use it and wait for my mechanic to get me a slot to bring the car in. It's running around 195 and has spiked up to 203 while on the highway doing 60 - 65 MPH. Do these cars typically have a 195 T-stat in them? Keep in mind it's 30 degrees here lately. Funny part is it's not really releasing air either when I open the rad cap and other then 2 times, it has not pushed out coolant. I swear that guy used some kinda head gasket crap in the coolant and the stuff is starting to now work since I've been using the car on the highway. Either way it's all coming apart but I wanted to know if this is a safe temp range to be in.
#67
IIRC, the stat is stamped either 88*C or 92*C? That would make it 190* or 197*F. It's been a while and I don't get to change them very often....
I'm on a sloooow net connection right now so I'm not going to do any looking for proper info.
Operating temp can be anywhere between thermostat opening and radiator fan running (212-220ish?). You are still well within the normal ranges.
Driving steady highway speeds at 30*F ambient temp, I sort of expect that it shouldn't go much over the thermostat temp rating since ram air will keep the radiator very cool. BUT if you are in traffic and on hills, that might make a huge difference.
#68
Ok thanks for the info guys! Being from the old school, the Grand Nationals called for a 180 stat only to find out years later that's way to hot for them so everyone runs a 160 in them now. Heat soaking is a bitch with those cars. I know the newer emissions cars run better with a higher engine operating temps (drives me nuts but I deal with it) so I let it be. I just thought hitting 203 might have been a touch hot for the cold temps here. I'm just trying to milk a few more days out of it while my mechanic gets the spot to get me in. I'm keeping a close eye on her that's for sure. I check the rad and overflow every time before I start out somewhere. I have the scan tool drapped over the rear view mirror so it's right in my face as I drive. People must wonder what the hell that giant thing is hanging from his mirror! lol
While I'm thinking of scan tools... any suggestions for these cars. I'd like to buy something reasonably priced, smaller, and easy to move around I can run in the car all the time. I like to watch my numbers. I've seen so many out there I'm just wondering if guys with Honda's find a good all around one that does it all live data and don't cost a ton. I think I've seen the Scan Gauge II in some pics on the forum here. Those things are so hard to buy. We have one for the Buick's called a ScanMaster and it's the best thing since sliced bread. Gives you super fast data and don't cost an arm and a leg. So if you have any tips for a nice Scan Tool please post as I'll be looking into one for my Civic going forward.
Thanks again for your input guys!
#69
FYI, the vast majority of GM products since at least the late 80s used 195* thermostats, and run the radiator fans at around 226*.
You stick a 180 stat in one that calls for 195 and you lost gas mileage right away.
Probably still true as of now, but I have been away from GMs for a few years now. High pressure EFI doesn't have hot soak vapor lock problems.... and newer stuff doesn't have starter heat soak problems either.
No idea on the scanner question, they are all over the map. You get what you pay for.
I use the factory HDS program.
Google Scangauge?
Google Scangauge?
#70
Rep Power: 0 Re: New 2005 Civic Owner here! Stop in and school me a little!
#71
Whachya lookin at?
Rep Power: 288 Re: New 2005 Civic Owner here! Stop in and school me a little!
Going back a bit but believe it or not those cabin filters don't actually look that bad. Mine are probably way worse in there right now
#72
Well everyone say a prayer for me she is in surgery now! The tear down has begun! I'm going to stop by and see how he's making out with her on Saturday. He's hoping to have the head off today and to the machine shop to check it out and clean it up. Just hope there are no extra gremlins as he goes! I should have a damn near new engine bay when this is all done!
He had a newer Accord in there the other day he was working on bitching up a storm because he had to remove the intake the change the starter!
#73
Even less room to do the job on a CRV 2.4L.
#74
Things are moving along great! Might even be running again tomorrow. Found a few items I needed from the dealer...
Injector o rings
EGR gasket
TB gasket
Some smaller coolant hoses
That's about all we missed. The best news is the head is perfect! Not warped and it cleaned up like new from the machine shop. Pistons seemed a little heavy on the carbon build up. I guess cheap oil? Cheap gas? Not getting on it much? Large gap between oil changes? What do you guys think? So have a look and let me know what you guys think! I'm surprised there is no oil leaks anywhere on the block.
And here are the pics!
Injector o rings
EGR gasket
TB gasket
#75
Don't worry about it.
Carbon on top of the pistons is normal and expected.
If you want to do something, make sure to use Top Tier Gas:
http://www.toptiergas.com/
http://www.toptiergas.com/retailers.html
EGR distribution plate is cleaned-- excellent.
Are you gonna put on a fresh timing belt while it is apart?
#76
Oh yes it's all new going back together! Don't know if you can tell but he cut the timing belt just to get it off easy. It didn't look that bad. Gotta wonder how much longer it would have lasted. He said my drive belts were rotted to hell and yet the timing belt looks great! He said the tensioner is good. New water pump and such will go on as well.
No oil consumption issues for the time I've had it. I'll get some of that Top Tier Gas for sure. Figure the carbon on top might hurt my MPG a little.
If you look at the pic with the top of the engine I can see a few spots it looks like that head gasket went.
#77
Hell, half the time I can't tell either, and I KNOW which cylinder is leaking long before I get approval to tear it apart.
#78
Head is back on. He chased me out to work on the car today Hopefully Monday or Tuesday!
#79
#80
Hey guys! I don't how to post a thread so i'll post here:
First and foremost, I do not know much about cars, and my car is a honda civic 2004 sedan. My car broke down during the winter storm last friday and just abruptly shut off in the middle of the street. It was towed to the nearest autoshop, and when inspected a couple days later, several mechanics said it was a timing belt problem. HOWEVER, my father replaced the timing belt via a dealership about 2 years ago and they have records of it on their computer. The dealership stated that although they replaced the belt, they may have not replaced the tensioner of the belt and that we would still need to pay. Additionally, my father is telling me that it is better off getting a new car instead, as the repair and labor is worth more than the car itself. What should i do? A friend from pep boys said that i may want to look into buying a new engine online for cheap, and that pep boys would repair for far less. Please help! I do not know what to do and i greatly miss my car
#81
these comments would really concern me as to the level of your mechanics experience/knowledge....why would he need to cut the timing belt? that is not normal practice, just release the tensioner and remove it....makes no sense....it didnt look that bad?.....timing belts dont show any visable signs of wear, thats why u need to go by mileage and age/years.....sorry but i am really questioning your mechanics experience going by these comments, and i would be worried if this guy was working on my car
#82
It was more like put your car back together or get out of my way. From looking at it now and reading the DIY's on here I'm sure I could have tackled it on my own. No lift, no time, and I'm not putting my Buick outside in the winter. I actually run water and rmi in them so I can't have them out in the cold for long. As long as you have a torque wrench and a lift didn't look bad at all.
#83
water and rmi
#84
You also can actually tell they are going bad, since he cut it, I was able to fold it over backwards and I could see the start of cracking between the ribs. So yea it was starting the dry rot phase so the end was in site. Since that also is the thinnest part of the belt I could see that as a break point down the road if not changed. I'd say maybe another 20K would have been pushing it.
#85
http://www.rmi25.com/
#86
I actually was a store manager for pep boys some years ago. I would stay away from them for repairs. They can barely do tires right! Getting another engine is not a good way to go. Who knows who beat the ***** off that engine and you'll most likely need to do a timing belt on the engine you buy no less or who knows what other repairs. Find a local reputable mechanic and have him look at it. I mean it is possible the timing belt snapped even if it was new. Who knows maybe they didn't install it right as anything is possible. But I would do some local shopping around for a good mechanic who can take a look at it. You can get the timing cover off and see what's going on in there without to much pain. I think my local dealer was 459 for a timing belt service.
#87
no, he has not saved you anything yet, that is yet to be determined.....
unless your tensioner lasts till your next timing belt change, you have not saved anything, you could end up losing money big time if it fails between now and then....
dont count the chickens before they have hatched
#88
7th Gen Civic DIY Enthusiast!
Rep Power: 161 Re: New 2005 Civic Owner here! Stop in and school me a little!
ezone did save him money on his advice not to change it based on ezones vast experience at a dealership with thousands of honda cars. I'm sure his advice not to change it was based on his experience that everything was reinstalled and tightened correctly.
I'm sure if ezone thought it was a high failure item he wouldn't have mentioned not changing it.
#89
Ok, it's only one bolt and let's assume it may have gotten installed correctly......
Now, how about the problem of people buying inferior, counterfeit parts at their local (open on Sunday) CHINAZONE? Those may only last a few thousand miles, and cost you THOUSANDS of dollars in the end....right? (Note: The COST of that cheap PRICE).
If I say (or we all say) 'Oh, you GOTTA replace that tensioner set!', most average DIY people are going to choke on the dealers high price and go shop at ChinaZone.
Now we look like we just 8===D (_o_) 'd him for telling him that the car NEEDED it, when all it did was cost them an engine.
Because all parts are the same, right? Few people will see that their cheapassedness is what cost them an engine. All they see is that something crapped the bed.
In this case, the original part is superior to the replacement part.
My experience has been (and I have come to expect) that the OE part commonly lasts to well past 200k. The earliest failure of the OE tensioner and spring that I/we have witnessed in the shop was around a quarter million miles. This is why we don't normally replace the part upon the first timing belt change interval, but it DOES get recommended at the next service interval.
Plus, the part may be priced at $134-$200+, depending on which greedy SOB is working at the parts counter that day. Hard to sell the timing belt job with parts priced that high, and the dealer is already high to start with.
I really hate the hard sell too. "You car is held hostage and you HAVE to buy this part or else you will crash into a school bus full of Nuns on their way to the Orphanage, and everyone will die in a huge ball of fire."
/damn, did I just write that?
//no coffee
#90
even seeing the part wouldnt matter.....nobody can guarantee a tensioner will last over 200,000 miles....sorry, not possible....no money has been saved yet until the engine is run till its next timing belt change....therefore i will stick with my original comment, yet to be determined
if the tensioner lasts another 100,000 miles then yes, he saved him money.....however, if it fails, he has cost him thousands of dollars
