Radio Antenna
Radio Antenna
Hello all. I have an 01 Civic LX Coupe and I was wondering if there was a way to run the fender-mounted antenna to the roof of the car. Can this be done? And if so, how so?
Re: Radio Antenna
The radio antenna is built into rear window grid.
What is on your fender?
1 Post
Rep Power: 176 Re: Radio Antenna
Ya, he's right. I've thought of moving mine from the rear glass to the roof or the fender though with a "whip" style. The rear defroster grid being so close in proximity makes interference in the radio. Plus you can get an aftermarket grid that will cover all the windows instead of a third of it The stock wire plugs to the stock antenna booster in the trunk, if yours is stock you can find it there. The booster is a black box about 3" square. (If yours is in the fender to begin with though it isn't stock, don't really know off hand where the connectors are.
1 Post
Not to highjack, but anyone searching may find this thread and be helped....
A complete stick kit, (everything that sticks to the class, since the wiring etc is there on our cars we don't need the whole kit), is only $30-35. If you have something else it is only around $50 bucks for the wiring too. If you are a diyer like me that is cheaper than getting the back glass replaced to fix a non repairable grid (the same company sells repair kits too, mine is so damaged before I got it the bottom 3 lines are non functional anyway, sucky when 6 inches or so is all that melts snow and ice
Re: Radio Antenna
Thank you!! I don't know why I was under the impression the antenna was fender-mounted...this actually helped and I plan to follow through with this. Thanks a lot.
ricer_em2
05-11-2016 08:09 PM
thebmillz
Electronics
10-02-2015 08:38 PM
jpat21
09-03-2015 11:32 PM
