cooling problem???
Old 12-01-2012
DEZZIE41's Avatar
DEZZIE41 is an unknown quantity at this point
Question cooling problem???
replaced thermostat, and new coolant, and after getting to operating temp, the top rad hose has some pressure and is hot, and the lower hose has very little pressure, and is still cold? is this normal???
DEZZIE41 is offline
Old 12-01-2012
DEZZIE41's Avatar
Re: cooling problem???
also my fan has not kicked in and its been running in my gargae for almost an hour now please help as im driving this acrss the country next month
DEZZIE41 is offline
Old 12-01-2012
mikey1's Avatar
what is your temp guage reading?
the fan wont come on unless the temp reads very high
mikey1 is offline
Old 12-01-2012
Both hoses have the exact same amount of pressure in them.
You need to understand how the cooling system works, and what the job of a radiator (heat exchanger) is, before you think anything is wrong.
How cold is it out there?
Car outside?
Is there a breeze?
If the temp gauge reading looks high, then something is really wrong. The gauge should remain in the normal spot from the point the stat opens to the time the fans run. The "normal" spot on the gauge covers a broad range of temperature (approx 170-220?) without hardly any movement at all.
ezone is offline
Old 12-01-2012
sl33pyriceboi's Avatar
Did you replace it with an oem or aftermarket thermostat. Did you replace the gasket as well?
sl33pyriceboi is offline
TXcivic2001ex
Air Conditioning
23
07-20-2020 07:27 AM
Reginator
06-13-2015 02:28 PM
Lopes101
06-07-2015 08:04 PM
brian257
06-04-2015 08:17 PM
dinsum
05-28-2015 09:30 PM
Quick Reply: cooling problem???
