Fog lights no longer working
Old 11-22-2012
I am Epic
Civicnoobie's Avatar
Civicnoobie should not be trustedCivicnoobie should not be trustedCivicnoobie should not be trustedCivicnoobie should not be trusted
double checked the connection at the on/off switch connector (inside the car) and its fine but notice when I took the button off one of the lights if out. Not sure if normal. Not sure how to go about fixing this. Really hoping its a simply fix and dont have to replace the whole set.
I do get an audible "click" when I press the button from the relay, which tells me that it's working if I'm not mistaken? Bulbs are 2 months old, fuse is connected to the relay on same wire but i dont know how to check it cause it seems the fuse has a cap on it but i tried and doesnt come off. Didnt want to bust anything.
Civicnoobie is offline
Old 11-23-2012
Prelude Owner
GolNat's Avatar
Re: Fog lights no longer working
A clicking relay could still be bad relay. Do you have a multimeter? The fuse should come apart so you can change it. If you break it buy a new one.
GolNat is offline
Old 11-23-2012
I am Epic
Got fixed it was the relay. Guess garbage relay. Got better one and also put cree bulbs in my reverse lights looks real nice! Wow bright!
Old 11-23-2012
Kenny the Ricer
Kennykid2002's Avatar
Almost always is the problem with relays. Very common with ebay kits.
Kennykid2002 is offline
Old 11-23-2012
I am Epic
Well hope the new relay lasts longer than 3 months. Suppose to be real good brand. But these Cree reverse lights wow, highlight of my day.
CivicS
11-22-2001 10:51 AM
klam
11-19-2001 05:46 AM
klam
11-16-2001 03:36 PM
780
11-13-2001 09:32 PM
WhosYoDadday85
11-11-2001 05:41 PM
Quick Reply: Fog lights no longer working
