Aftermarket stereo removal wiring
Old 11-08-2012
mmatlock's Avatar
mmatlock is an unknown quantity at this point
I removed a car stereo that I was going to sell, but ran into a few problems. I removed the trim, gear trim, center console trim, head unit, but couldn't access the other end of the wiring harness adapter. Also, the antenna adapter runs down the behind the head unit into an area where I can't reach and have no clue on how to pull that all apart since I haven't seen any videos on it.
mmatlock is offline
Old 11-08-2012
Kenny the Ricer
Kennykid2002's Avatar
Re: Aftermarket stereo removal wiring
You should be able to take the head unit out, unplug the wiring harness and antenna from the back of the unit.
Once that's done, you can yank the harness out until you reach the connection point between the aftermarket adapter and stock harness.
Kennykid2002 is offline
Old 11-08-2012
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
As Kenny said, unless they zip tied everything down, the harness should be loose enough and long enough to reach the front opening. Same with the antenna adapter.
TiggerDX is offline
Old 11-08-2012
Kenny the Ricer
That is, unless whoever installed it decided to cut the stock harness and solder the aftermarket harness on.
I've seen it before.
Default_Slayer
Electrical DIY
12-04-2022 07:56 AM
dbagaus
06-10-2015 09:29 AM
Youngciviboy
06-10-2015 03:49 AM
4 banger
06-05-2015 01:44 AM
Dmitri
123
10-13-2005 08:01 PM
Quick Reply: Aftermarket stereo removal wiring
