p0304 misfire 2002 lx, WHAT NEXT?
Rep Power: 0 p0304 misfire 2002 lx, WHAT NEXT?
i have swapped coils, injectors and done a compression test and it still comes back saying cylinder 4 misfire. iono what to check next. Im thinkin bout checking wiring that goes to coils or valve adjustment(never done one)...i can only feel it misfire randomly at idle but it runs fine when i give it gas...advice?
p.s. how bad would it be to drive 500+ miles with this code spittin out?
Re: p0304 misfire 2002 lx, WHAT NEXT?
What are the results of your compression test?
What is the MAP Voltage at hot idle, in neutral or park, with no loads?
Both of the above might lead me to some sort of conclusion about the valves.....Why haven't you adjusted the valves already?
(Don't bother answering that. Just do it.)
Depends.
Rep Power: 0 Re: p0304 misfire 2002 lx, WHAT NEXT?
i had an independent shop do it and they told me...
cylinder 1- holding 80% (rings)
cylinder 2- holding 80% (rings)
cylinder 3- holding 97%
cylinder 4- holding 94%
they put rings in parentheses telling me the rings wearing out are the reason its not holding so well
iono what that is or how to check but i do have a multi meter.(?)
ive never knew of this as a routine/preventitive maintance job until reading and asking around about this misfire. if its holding good compression wouldnt that say on its own the valves are fine?
Some history for this car, ive recently(within the last month) changed head gasket, timing belt(just re-adjusted time to fix hi idling issue 2 weeks ago), waterpump, thermostat, hoses, had the head cleaned and leak checked at some hole in the wall head shop, intake manifold gasket, and valve cover seals. the original issue was blown headgasket and i just did the rest since i was going that deep into it
TYIA
TYIA
This test should only come AFTER a compression test that gave poor results.
This does not explain a #4 misfire yet.
And you don't have any results from a compression test here to evaluate anyway.
New question: What is the Freeze Frame data from the P0304 misfire code? Post that so I can read it..
If the check engine light is still on, go to a parts store and get the code read---AND get the freeze frame data. Printout or write it all down.
so i did a proper compression test just a dry run since the oil can i got isnt working
4 - 134
3 - 161
2 - 163
1 - 139
didnt have time for the freeze frame data today...and could i get info on gettin map voltage
4 - 134
3 - 161
2 - 163
1 - 139
Actually, all 4 are lower than my typical results. I expect 180-220 out of these engines.
Did a leak down today...set cyl 4 tdc best I could only turning the cam, and It was losing 35% an could here obvious air blowing thru the hole on the valve cover that goes to the intake filter case...when I would plug it with my finger I would hear air flow from the #1 spark Plug hole....not covering anything i could hear a lil in the crank case and tad bit from the throttle body...radiator wasn't giving off any noise...it was low coolant tho so ima top off later do it again and see if any bubbles come out...I then did cylinder 1, set it to tdc using camshaft again. It had a 50% leak, heard no air coming from the intake vaccum line tho on the top of the valve cover but I did hear noise in the number 3&4 cylinder spark plug holes...again I heard air from crank case and tad bit from throttle body with the throttle open
I'm going to do a valve adjustment after work tonight since it'll be about 70 degrees tonight and cars been sitting for 2 days...I've never done one before but after watching some vids it doesn't look to hard
Can only learn by doing and hopefully this ****'ll fix my misfire
Yes, check and adjust valves. Gotta make sure the valves can shut completely.
i just finished up with the valve adjustment and noticed they were ALL tight as ****....i did a compression test on cylinder 4 and AMAZINGLY it went up to 180!!! couldnt believe it so i did it again and same results...didnt have time for the rest of the cylinders but ima get to em in the morning....but the 180 makes me feel good
thanks for the support ezone
I put everything back together and it's running sooooooo smooth...if anyone has similar misfire issues then valve adjustment should do the trick
Rep Power: 0 Thread
MamaBear2015
49
09-29-2015 01:12 PM
msaeger
09-02-2015 08:47 AM
