Transmission probs
Rep Power: 0 Transmission probs
I have this problem with my transmission and was wondering if anyone could tell me what it is. The axel won't go fully into the transmission and there is a rod blocking it.
Re: Transmission probs
That's supposed to be there. It's the cross shaft for the spider gears.
You get a wrong axle? Compare to the old one.
Rep Power: 0 Re: Transmission probs
Well bought it about 4 months ago cause the boot was ripped and replaced it but it went in fine back then. I was driving and it slipped out. Now it won't go back in like normal. Shouldn't it push all the way to wall of the tranny to be flush? And is there any way to move it out of the way?
2) Does it still have the snap ring near the tip? I have seen them twist off the end at the snap ring groove if it was slipped out while under a lot of power.
3) Are the splines twisted now? Same reason as above.
Should not be completely flush with the trans, there has to be a bit of room for things to move---maybe 1/8 to 1/4 inch?. Should slip in to the point that the snap ring can expand and lock it in place.
Got pics?
1) How far DOES it go back in?
Got pics?
Got pics?
There is still a snap ring at the tip of the axel and there is no twists in the spline. But the snap ring doesn't snap in
I'd need to compare to a fresh axle to be sure, but it looks like the short stub (to the left of the snap ring) used to have actual splines on it.
Like they got sheared down.
And it is keeping the snap ring trapped (or the ring never expanded properly to lock the axle into the trans).
The snap ring seems like it is collapsed or trapped in its groove now.
It should be able to expand so half the width of the ring is bigger than the splines, but right now it looks compressed.
I think you need to try a fresh axle.
it just seems like that rod wasnt there before. cause i sent the picture to my mechanic buddy who works mainly on hondas and said that wasnt normal. because i can feel the axel hitting that rod and stopping it about halfway.
Yeah, i still haven't figured out what the fix is. im gonna make it to the parts store today to see if i can get a new axel.
Anyone ever had their tranny cut out when shifting into 3rd or 4th gear?
My 2000 DX, which is an automatic just revs as if it was in neutral when I keep my foot on the gas. It is an automatic transmission. My first guess is that the transmission is just gone, but it still starts fine and goes into drive at first and i can even put it in reverse, just cuts out after about 30 seconds or if I try to push it into 3rd or 4th.
Ive heard that this could be the throttle valve cable being out of adjustment and needs to be adjusted, but im not sure how to adjust it...
Anything would be helpful.
Thanks.
Thanks.
Elciteeve
09-28-2015 12:40 PM
jerry38
09-20-2015 08:38 AM
