2004 EX Turn Signal Failure
Old 09-30-2012
Upinsmoke561's Avatar
Upinsmoke561 is an unknown quantity at this point
This is my first post here. Just recently my turn signals stopped working. My emergency flashers still work. I read up on google of similar issues but I noticed in most people's case, both the turn signals and the emergency lights went out. I've checked my fuses but they were fine. I need help ASAP.
Also, my airbag light appeared on my dash. Again, I checked the fuse but it was fine. This seems like a huge problem now that my turn signals are gone. I would appreciate any advice, as my knowledge of vehicle repair is limited.
Thanks for reading
Upinsmoke561 is offline
Old 09-30-2012
Re: 2004 EX Turn Signal Failure
Airbag and turn signals should not be related to each other.
Search for how to read airbag (SRS) codes, and what they mean.
If it turns out to be a buckle switch, many dealers will warranty them. Others won't.
Some common codes I see are caused by a low battery.
Some actually need real help.
See what you got.
For the turn signals, make sure all 4 corners actually flash when the hazards are on....
then I'd get a good wire diagram and be checking at the turn signal switch first.
If I can jumper around the switch and make them work, then I know what the problem would be.
HTH
ezone is offline
steveneddy
05-19-2015 02:39 PM
shaejb15
04-26-2015 07:44 PM
Fastfebur
04-22-2015 01:37 PM
wawacito
05-14-2002 07:33 PM
my2k1vic
01-08-2002 08:31 PM
Quick Reply: 2004 EX Turn Signal Failure
