Sponsored by:
Sponsored by: DashLynx
door lock
Old 09-06-2012
mikey1's Avatar
door lock
my rear drivers side door (4 door) lock will not work (electronically) but will work manually....i took the door apart and replaced the electronic locking mechanism/motor.....but it still wont work, 3 other locks work fine....where to look now?
mikey1 is offline
Old 09-06-2012
got2run5's Avatar
got2run5 will become famous soon enoughgot2run5 will become famous soon enough
Re: door lock
Test all the wires running from the switch to the lock actuator. One is probably broken somewhere.
got2run5 is offline
Old 09-06-2012
raymondxcho's Avatar
raymondxcho is an unknown quantity at this point
Re: door lock
I'll bet that it's your actuator.
When my driver's side actuator was bad, the door would want to lock but couldn't. Replacing the actuator fixed the problem.
raymondxcho is offline
Old 09-07-2012
mikey1's Avatar
Re: door lock
what do you mean actuator?
i have replaced the electronic thinggy that the wires connect to, it still does not work, even when only connected to the wires and not the door itself, so i know that is the problem, its not getting power but i dont know why
mikey1 is offline
Old 09-07-2012
CraigW's Avatar
Re: door lock
Broken wire or bad connection (open circuit)
CraigW is offline
Old 09-10-2012
mikey1's Avatar
Re: door lock
yup thats what it was, actually two wires were broken inside the rubber boot that connects the door to the frame, this part pivots everytime you open the door, so i guess thats why
mikey1 is offline
Aladinbama
08-23-2015 06:37 AM
viperGTS
07-27-2015 08:40 PM
ayoitzjulesdx98
07-26-2015 02:25 PM
ballmich
07-09-2015 11:59 AM
Spanky4269
07-05-2015 09:40 PM
Quick Reply: door lock
