Auto Transmission Update + Possible Reliable Rebuilt Trans
Rep Power: 0 Auto Transmission Update + Possible Reliable Rebuilt Trans
First, I would like thank gearbox for recommending a flush with Valvoline MaxLife. I have an 02 with about 100,000miles and transmissions shifts and drives a lot better than with the Honda ATF. I had a bit of slippage and now its totally gone.. at least in the warm weather.. I will keep everybody posted if it comes back when it gets colder.
Second, I know there hasn't been many successful shops that have rebuilt our transmissions, but check out these rebuilt civic transmissions. They have identified and corrected all the defects this board has discussed in the past. For $995, it seems like a good deal if it turns out to be a solid rebuild.
What do you guys think?
The transmissions have been overhauled with:
· New steel and friction clutches
· All new o-rings and seals
· A new internal filter
· New torque converter
· New differential bearings
· Dyno testing done on all transmissions
· An add-on external filter with magnet to catch debris from old transmission.
· All are updated, and come with A WRITTEN 24 MONTH WARRANTY
Updates Include:
· Increasing the pressure in the valve body to the torque converter so it lasts longer
· A new HEAVY DUTY torque converter
· An external filter
http://www.ebay.com/itm/2001-2005-HO...=mtr#vi-ilComp
http://www.willowcreektransmissions.com/
Updates Include:
Re: Auto Transmission Update + Possible Reliable Rebuilt Trans
of course it shifts alot better, the fluid is brand new, it has nothing to do with the type of fluid you used....chances are the slippage will return, new fluid will not fix a problem, it will only disguise it for a short period of time
1 Post
Rep Power: 176 Re: Auto Transmission Update + Possible Reliable Rebuilt Trans
The viscosity is the reason, not only new fluid. That helps, but the properties of the new does the "magic".
I have no knowledge there. I built my own for half that and it has close to 40k on it. I know, out of most guys scope. The only question I have is this, what kind of car to you have? It will work, is it the "best"? Dunno. BMXA I believe was only in EX trims. The difference was in mainly the shift logic and the ratio of gears. In short, it will work, but may not be the same as it was. The reason was difference in HP from VTEC to not VTEC, and the short ratio in EX trannies make the VTEC closer to cruise rpms. This is also why LXs tend to get better mileage than EXs. My EX cruises between 3500 rpms and 4000 rpms at 70 mph.
Rep Power: 0 Re: Auto Transmission Update + Possible Reliable Rebuilt Trans
Sorry, I should have mentioned that I drained/filled the transmission on average every 30-35,000miles with Honda ATF. When I switched over, the Honda fluid that came out looked brand new, just a bit darker red than the brand new maxlife. Not sure what your "short" period of time is, but I flushed it back in May, not a single slip since.
Rich
1 Post
That is the same size as I have. Stockers. I think mine may be a couple miles off. I'll check it tomorrow.
Auto for you too?
Auto for you too?
Rep Power: 787 Re: Auto Transmission Update + Possible Reliable Rebuilt Trans
maxlife is a good fluid and with its lower viscosity will start working/warming up faster than the honda stuff. so it the summer you wouldnt notice anything but in winter it will prolly still slip until warm. but it is thin enough that it wont take as long.
Mines an 04 just drove from Chicago to SW Michigan, at 3K RPM it's traveling at 75~76MPH.
My main complaint with this vehicle is compared to my 1992 5.0 T-Bird the wind noise is god awful. At 70 you could open the passenger window 2 to 3 inches and the noise level would only go up 3dB in the bird.
Rich
Rich
Rich
Rich
1 Post
Under 3 at 75 is why LXs tend to get better mileage. (Disclaimer: This is highway, NOT stop and go like a huge percentage of us do most of the time we're driving.) I usually avg around 32 mpg with a few tanks of all highway when I go on vacation and such. I don't mean 100 miles of hwy, I mean 800 to 1000 miles. 2 or 3 tanks...
Heard alot of guys say they are regularly in the high 30s, a few more too.
on edit: Sorry OP you had a good topic, I kinda got it of course....
So my second question is there any reliable rebuild kits out there? Any vendors that sell brand new Honda automatic transmissions?
you wouldnt want a new honda trans. it will have the same problems after a while. the only rebuild kit ive seen that actually works is the tci master racing kit that members used with turbo and never had slippage.
yeah its been discontinued but i believe someone recently posted that you can get it thru ALTO (the company that makes the red eagle clutches for the above kit).
lapchern
06-04-2015 04:35 PM
MajTom
06-02-2015 11:48 AM
davidpaustin
04-29-2015 02:23 PM
C6GrandSport
04-25-2015 09:41 PM
