01 Civic Mats and Interior Questions
Rep Power: 0 01 Civic Mats and Interior Questions
Are these the OEM mats that came with that yr LX? Its the first on the list that just says Floor Mats. I want to make sure before I make the order!! http://handa-accessories.com/civint01.html
I just got my Civic and theres no cover over the outlet that you use with a phone charger. It works but its just a open hole. Is there supposed to be a cover and can I find it anywhere online for cheap? Or should I try looking at a junk yard?
Theres 2 open spaces in my car in the parts I circled. Does the bottom 1 have an ashtray or did it come as an open space? Where can I get the cover for the top part under the head unit?
The light is out in the **** that adjusts where the ac is blowing (head, head/feet, etc). How do I replace it?
Thanks guys. The interior is in pretty good shape besdies these stupid things
Rep Power: 0 Re: 01 Civic Mats and Interior Questions
First of all, I just want to say that that interior looks very nice. I never really knew what the beige interior looked like for our Civics. I really like the beige. I have the black interior.
Anyways, yes those are the floor mats. It says you can pick your color too.
The outlet does have a cover for it. Is it absolutely necessary to have it? No, but like you said, I'm pretty sure you can find one a t a junkyard for dirt cheap. I wonder how yours came off lol
As for the open spaces, that's how they were designed. The little door under the head unit IS the cover for the compartment inside. The tiny space down below is just there. No ashtray. I keep my sunglasses in there.
**** mine doesnt have the little door!! How would I even put one on? I dont see how it would snap or screw in place. I bet it got broken off when the previous owner installed their WalMart head unit
I've had two 7th gens and both have had the cigarette lighter cover break off...it may not even be worth replacing
As for the door cover on the headunit, if the door has been snapped off it's easiest to buy a whole new pocket. You technically could just get a new door but good luck finding a door complete with springs.
To install you need to take out the center dash (the thing that holds the radio, climate controls, etc.) and unscrew the pocket from the back of the dash, slide it out and put the new one in.
Rep Power: 232 Re: 01 Civic Mats and Interior Questions
well i know on the 04 when you get an aftermarket radio the you have to replace that entire piece and the new piece is different im not sure if this applies to that year though.
Yeah like lowlife said, usually when someone replaces the head unit in our Civics, they have to replace the little compartment under it too. And that usually means the door goes missing.
I don't have that door under mine either after I replaced my head unit. I do miss that door.
Rep Power: 165 Re: 01 Civic Mats and Interior Questions
By saying that it "gos missing" implies that it was lost. When an aftermarket hu is put in, the old compartment is replaced. I believe there is one kit that keeps the door but 99% of the time the aftermarket kit has a smaller space and no place for the door.
Unless you're trying to make it look 100% stock I'd put in a double din aftermarket head unit. It looks much better than the stupid single din and pocket.
Its awesome how much cleaner & better the interior looks with new oem mats!! the beige interior in 01 Civics looks really smooth & nice!
aZnVoYCe
Bolt-on Engine Performance
11-04-2001 10:18 AM
