Lights dimming
Rep Power: 0 Lights dimming
Hi! I have 04 LX 92k..I realized that when the car is idle and AC kicks in, headlights and the lambs inside dim.
Battery is little bir old. Is the problem battery? or what?
Thanks
Thanks
Rep Power: 787 Re: Lights dimming
exactly, considering the a/c system and fan use close to 500w of power. it never hurts to check the battery if you think its getting old. usually failures happen gradually and you will notice slower cranking as the first sign.
Re: Lights dimming
2 fans and a clutch is probably consuming somewhere between 20 and 25 amps,
Quite a sudden load because they all turn on at the same time when the compressor cycles.
(In addition to the inside blower, which may be up to 15 amps, depending on what it is set at)....
The lights do dim noticeably.
Normal.
Ever hit all 4 power window switches all at the same time, after the windows stopped moving? The headlights will dim then too. Still normal.
Normal.
4 banger
06-05-2015 01:44 AM
civic_gt
04-19-2015 08:15 AM
SSMatey
04-13-2015 06:09 PM
