Sponsored by:
Sponsored by: DashLynx
Alignment issue
Old 07-10-2012
paulymcd7's Avatar
paulymcd7 is an unknown quantity at this point
Alignment issue
took my car to get an alignment and my mechanic has my tie bar nut brought in all the way no more threads are showing and im still toed in a little 1.3 degrees he said i need an adjustable ball joint does this all make sense? i dont know much about ball joints and front suspension a little but not enough
paulymcd7 is offline
Old 07-10-2012
lowlife9's Avatar
Re: Alignment issue
are you on stock suspension ???
lowlife9 is offline
Old 07-11-2012
paulymcd7's Avatar
Re: Alignment issue
not anymore no
Old 07-11-2012
paulymcd7's Avatar
Re: Alignment issue
i know a ball joint can affect camber but i dont see how it affects toe, my tie rod end boots are fine so i dont think its the tie rod if it isnt the ball joint then the control arm is bent he said and there is evidence of a passenger side accident up front so its a possibility. but i just wanna make sure an adjustable ball joint to fix camber is the way to go and where to get one because i cant find one. he fixed driver side camber with stock ball joint if that changes anything
Old 07-11-2012
paulymcd7's Avatar
Re: Alignment issue
Bump. is adjustable ball joint what I need where can I get one?
Old 07-12-2012
paulymcd7's Avatar
Re: Alignment issue
bump
Old 07-12-2012
sl33pyriceboi's Avatar
Re: Alignment issue
the tie rods effect toe.
sl33pyriceboi is offline
Old 07-12-2012
paulymcd7's Avatar
Re: Alignment issue
But my boots look fine so I don't see why it would be a tie rod end there is a suspicion that my control arm is bent but he "can't figure that out until he fixes the camber" I just don't get why he says he needs to fix camber to fix toe I can understand if my ball joint is bad but that shouldn't affect my toe especially of my tie bar adjustment nut is cranked all the way in
Old 07-13-2012
Received 1,440 Likes on 1,196 Posts
Re: Alignment issue
there's no adjustable ball joints for a 2004...
control arms are not expensive.
sdaidoji is offline
Old 07-14-2012
CO&CA
TFMEX's Avatar
TFMEX is a jewel in the roughTFMEX is a jewel in the roughTFMEX is a jewel in the rough
Re: Alignment issue
inverted tie rod ends, shorter tie rods or raise your car
TFMEX is offline
Old 07-14-2012
paulymcd7's Avatar
Re: Alignment issue
but i still have threads showing on driver side passenger is cranked in all the way im pretty sure my control arm is bent i have a guy who's gonna tell me within a week
civicowner123
07-24-2015 10:02 PM
honda200192
05-31-2015 05:57 PM
bo_red
04-23-2015 10:09 PM
darelldd
02-26-2002 12:11 PM
ImmortalEX
10-31-2001 10:00 PM
Quick Reply: Alignment issue
