Key FOB
Re: Key FOB
01 LX did not come from the factory with keyless.
Someone would have had to buy it as an accessory installation.
Find the instructions for installing keyless entry, and see if it is already installed in your car. If it is, then all you should need is some fobs and to program them.
Instructions for an 03 look somewhat similar. http://techinfo.honda.com/rjanisis/pubs/AI/AII24178.pdf
HTH
HTH
Re: Key FOB
Start here http://estore.honda.com/
Pick Honda, then accessories,
In the right side column you should find a link for accessory install instructions. http://estore.honda.com/honda/access...your-honda.asp
That's where that earlier link came from.
Pick the oldest car similar to yours.
HTH
HTH
bolt-on-bandito
Electrical
32
01-15-2020 03:25 PM
thebmillz
Electronics
10-02-2015 08:38 PM
MamaBear2015
09-24-2015 11:34 AM
Klame9420
09-07-2015 10:03 PM
