Broken lug nut -- what should I do?
Rep Power: 0 Broken lug nut -- what should I do?
I was trying to take off one of my tires just a few minutes ago and one of the lug nuts was extremely hard to turn. I have no idea why, because I've taken that wheel off several times with no issues whatsoever. I kept turning it, despite the fact that I had to put all of my weight on the breaker bar to get it to turn, and the lug nut broke off with part of the stud inside it.
How bad is this? I have no idea what I should do
Rep Power: 0 Re: Broken lug nut -- what should I do?
Hi MindBomber,
Is this beyond the DIY capability of a n00b like myself? I tried calling a few shops a little bit ago, but they are all closed. They probably won't be open until next Tuesday, and I really need to drive before then.
Any suggestions?
Any suggestions?
Live for the Twisties
Rep Power: 260 Re: Broken lug nut -- what should I do?
If you're on a tight budget, you could remove the knuckle yourself and just have the shop handle replacing the stud, but that's a pretty high difficulty level.
Rep Power: 190 Re: Broken lug nut -- what should I do?
next time when putting your wheels back on use a torque wrench.. the reason why the stud broke was because you over tightened the lug nut
I have been using a torque wrench, actually. I've been torquing the lug nuts to 80 ft-lbs
Yes, there is more to it than that. It's impossible to just smack the stud out, because there's metal behind it and you would only be able to move it four-five millimeters. The hub needs to be separated from the knuckle to allow the stud to be removed and replaced, which usually involves replacing the wheel bearing as well. There's no DIY, because it's not DIYable for someone without a press and very few amateurs would have one. You can look at BlueEM2s ball joint DIY to see what's involved with removing the knuckle.
Received 1,440 Likes
I rented that axle puller tool and the slide hammer. It takes quite an arm muscle to do.
Anyone familiar to that?
I replaced all my studs by myself with ARP Wheels Studs.
You guys think I messed up my axle or something? Its been almost two years since I replaced it.
Well that was only the name of the tool. I just pulled the hub out, never the axle. And pop the broken or old wheel stud out and press the new ones in.
Sorry. I misinterpreted. I meant to ask about messing up my hubs and bearings, not the axle.
So, how did you get the bearing out of the hub?
Ah, okay. Most people replace the bearings when they press out the hub, because the process often to damage them and they're a wear part anyway. It doesn't necessarily damage them though, yours could be fine.
What do you guys make of this?
EDIT: OK, the stupid forum software will not let me post a youtube link with a time at the end, so paste the following in your address bar: youtube.com/watch?v=FEDrioMDe1k&t=1m30s
Hey MindBomber,
I've been following BlueEM2's ball joint DIY but have gotten stuck, unfortunately. I cannot get the lower ball joint to separate from the lower control arm. Nothing I have tried has worked. I've tried putting a ratchet handle in there, and then I tried a breaker bar handle (which is very thick.. nothing any thicker will fit in there, even with the lower control arm jacked up all the way). I've tried lowering the jack at full speed, and stepping on the rotor after it came down. The ball joint will not break free.
I noticed in BlueEM2's thread that you actually ran into this same problem. Can I ask how you managed to break yours free?
Thanks for your help
I've always used that method on 6th and 7th gens with my Craftsman breaker bar. It usually takes a few times but it always worked for me.
Just jack up the LCA so the breaker bar handle fits snug, and lower it at full speed, if it doesn't work try again.
Okay, well, if you try this do so at your own risk and be careful.
I placed a jack stand directly under the ball joint stud then very slowly lowered the car, once the suspension is fully compressed it will be forced to separate because the weight of the car will be against it.
I spent hours and hours trying to remove it using the trick BlueEM2 and Anibis used, among other things, before resorting to that.
No, that wouldn't be as stable as carefully lowering from a structural point. It will probably pop out suddenly, so going that route you would lose stability when it comes free.
Well, after spending literally six hours trying to separate the ball joint from the lower control arm, I was forced to give up as I was running out of daylight.
I tried the method you used, MindBomber, but even with the full weight of the car (well, maybe not the full weight, since the left tire was on the ground) that damn ball joint would not come out. I also tried putting the jack under the stud and jacking it up, but to no avail. I tried BlueEM2's method a few more times, using a crowbar with an extension on it to pry the joint off, as well as using the crowbar after dropping the joint down on it. I tried various other things, such as jumping on the rotor after dropping the control arm down with something under the ball joint, among other things, and the joint didn't even budge.
THIS IS THE BALL JOINT FROM HELL!
Lol :P I guess I'm going to have to take it to a mechanic, although I can't image how they will separate the ball joint from the lower control arm. I just hope it's not hundreds of dollars
Thanks for all of your help with this, MindBomber.
Mine was an absolute nightmare, worse than anything else I've encountered on the entire car.
The next step would be to try and find this tool.
http://www.harborfreight.com/3-4-qua...tor-99849.html
it's a ripoff of an OEM Honda tool.
http://www.kseriesparts.com/cr/HON-07MAC-SL00202.html
or take it to a mechanic, of course.
There's a good chance it will. I've heard of people who could not successfully break the ball joint free with the technique demonstrated by BlueEm2 but had success with the "proper" tool. I fought with mine for a full day before attempting the somewhat fool hardy technique I used, because I couldn't find that tool. If that tool doesn't work, I don't know what will short of a sledge hammer lol.
Rep Power: 338 Re: Broken lug nut -- what should I do?
the tool works, but might require moving the suspension up and down again. use a jack, it will pop out loudly
I used this. http://www.autozone.com/autozone/acc...lange/_/N-264h with this http://www.autozone.com/autozone/acc...uestid=1439218
They attached to each other and the first one bolts into the studs.. and then you hammer away. It works and its free. Don't make fun of me. Lol
