Sponsored by:
Sponsored by: DashLynx
projectors
Old 05-15-2012
paulymcd7's Avatar
paulymcd7 is an unknown quantity at this point
projectors
im gonna get these
http://www.ebay.com/itm/04-05-Civic-...#ht_4909wt_930
i know they wont be as good as name brand but are there monstrous downfalls of these? I'm gonna get HIDs soon too
paulymcd7 is offline
Old 05-15-2012
iridehonda's Avatar
iridehonda is an unknown quantity at this point
Re: projectors
Worse output than OEM headlights is one major downfall. Looks, depending on your taste is another.
For that price, is there any reason you don't want to go with morimoto minis?
iridehonda is offline
Old 05-15-2012
02whiteem2's Avatar
02whiteem2 is an unknown quantity at this point
Re: projectors
Hell if your gonna spend that much why not just get them minis. They will be much better than hids in those.
Last pic is when i was installing them. got 5k bulbs and the cutoff is amazing when driving.
if your afraid of messing up your lights just buy a second set. I got these TYC replicas of amazon for like $40 a piece and they haven't leaked at all.
02whiteem2 is offline
Old 05-15-2012
Live for the Twisties
MindBomber's Avatar
Re: projectors
OEM with Minis is infinitely better in every way
MindBomber is offline
Old 05-15-2012
Aetoc's Avatar
Aetoc will become famous soon enoughAetoc will become famous soon enough
Re: projectors
I have the exact same headlights with 5000k HIDs and let me tell you, they look pretty cool, I like the style...but output is inconsistent and the cutoff isn't solid. The only reason I bought them was cause they were used and they were cheap. If you're gonna buy them new, just retro mini h1s in your stock housing and save the extra $300 you're gonna have to spend on them to fix those eBay projectors.
Aetoc is offline
Old 05-15-2012
got2run5's Avatar
got2run5 will become famous soon enoughgot2run5 will become famous soon enough
Re: projectors
Yup, go with the minis. They just came out with a new harness that supposedly works without any modification in our cars as well. I haven't tried it yet but when I bought mine they said since they were coming out with the new one soon that they would refund my money for the old harness after buying the new harness.
got2run5 is offline
Old 05-15-2012
paulymcd7's Avatar
Re: projectors
okay im gonna do that.. can someone post a link to the best retrofitting diy on here? and what specific stuff should i get? im getting 6000k bulbs but what adapter plates shrouds and wire harness should i get? should i get resealing glue? there were a bunch of different kits im looking at the stage 3 kit but only because thats the first i clicked whats the difference between kits? and for fogs do i just tie the wires into the corresponding wires for the low beams?
Old 05-16-2012
Aetoc's Avatar
Re: projectors
The main difference between the kits is the ballasts they use...the more expensive kits use OEM ballasts which start up a bit faster than the morimotos. That being said, the morimotos still reach full temp in less than 5 seconds.
The h1 projector mounts into the stock headlight hole, which is a 9006, do that's the adapter plate you wanna use.
The shroud you want really depends on personal taste, just be aware that the larger ones will likely have to be cut to fit into the stock headlight, so to avoid that, just get the mini Gatling gun shroud.
And in terms of the harness, it's included with the kit, so don't worry about that.
The reselling glue is a good idea to use to make sure the housing is sealed properly from moisture around where the lens meets the housing, as well as where the projector mounts in the stock bulb hole.
And for the fog lights, if you get a proper OEM or replica kit (mine was $50) it comes with a wiring harness that includes a switch and relay that fits into the OEM locations under the dash...all the connectors plug right in.
Aetoc is offline
Old 05-16-2012
paulymcd7's Avatar
Re: projectors
is there a way that i can have the fogs turn on and off with the low beams with out flipping a switch like when my brights turn on i wan the fogs to turn off with the low beams without using the switch
Old 05-16-2012
Aetoc's Avatar
Re: projectors
Well if you wire the relay switch to the same switch wire for the HID relay then the fogs will come on with the headlights...but on an 04 the high and low beams stay on together when you switch to brights so the fog lights will be on anyway.
Aetoc is offline
Old 05-17-2012
paulymcd7's Avatar
Re: projectors
okay so i shouldnt have to worry about a ticket then?
Old 05-17-2012
got2run5's Avatar
Re: projectors
Ways to not get a ticket:
1.) Do a proper retrofit
1.1) Aim the beam at a decent height
2.) Use 4300k or 5000k bulbs for headlights. Anything above looks too blue and will have a cop on you in an instant. 4300 for best light output, 5000 for looks.
got2run5 is offline
Old 05-17-2012
Aetoc's Avatar
Re: projectors
^ What he said lol. You're not going to be driving into traffic with your hi-beams on anyway, so having them come on with the rest of the lights isn't gonna get you a ticket.
Aetoc is offline
wingsfan19
10-01-2015 03:45 AM
carid
06-05-2015 11:51 PM
Exbauer
04-03-2002 01:04 AM
AzNmiKex215
03-30-2002 10:08 PM
Diznavis
02-19-2002 12:41 PM
Quick Reply: projectors
