Power windows in a dx?
Delightfully tacky. Yet unrefined
I've got a 2005 coupe dx, and i'm dying to install power windows. Does everything bolt straight in? The wiring too? Can i get the stock power window buttons that fit in the door panel or do I have to make and place my own button or get a different door panel?
Re: Power windows in a dx?
So something like this: http://tinyurl.com/6ns3vxv will fit straight in? Doesn't look like they come with buttons so I'd need something like: http://tinyurl.com/8xynzzm right?
I couldn't find a "universal kit" on ebay.
01-HXcoupe
Rep Power: 0 Re: Power windows in a dx?
No, this should be best and a lot easier. I'm gonna do it on my 01 civic hx coupe in may
http://item.mobileweb.ebay.com/viewi...id=89807929729
When i had an 04 DX i actually converted it to power windows and it was a hell of a job. I found a donor LX at a junk yard, took all the insides of the doors, door panels, main wiring harness that goes behind the dashboard (that goes to the computer, instrument cluster, HVAC congtrols, and more), also took the computer, instrument cluster (so i had the tach) Keyless FOB control and a few other odds and ends. The whole swap including time spent at the junkyard probably took about 15 hours and cost me about 500$ but i think it was worth it in the end. here are some picts:
No, the only problem that i had was not realizing that i would need the immobilizer and key from the donor car so i had to make a second trip. It's not gonna be easy to get all those parts unless you buy a complete car or are good friends with the owner of a junkyard, and they let you go into the yard and take the parts yourself.
Yeah, going to get a whole stock set up looks to be pretty annoying. I'll probably pick up that kit you suggested since they are located near me :3
01-HXcoupe
Deffinetly don't do stock windows. It's gonna be a pain in the a$$. The aftermarket will be just as good and even if you don't feel like doing it yourself, the kit cost $100 and a professional in my area told me $200 to install. So that's only $300 for everything!
01-HXcoupe
Rep Power: 0 Thread
1khilari
07-09-2015 08:12 PM
ballmich
07-09-2015 11:59 AM
hayden55
07-08-2015 11:38 PM
cgavin1
07-07-2015 07:10 AM
04, 2005, 2007, aftermarket, civic, civicwindows, dx, hav, honda, install, installing, power, universal, window, windows
