Flywheel source?
Rep Power: 0 Flywheel source?
Hello all, I usually just read, however- I'm going to be replacing the clutch on the '04 as 200K miles has come and gone. I have an Exedy OE replacement on its way from rockauto.com but strangely enough they don't stock any flywheels. I even called to confirm. Since the tranny will be out, I might as well throw on a new flywheel while I'm at it. Other than eBay, does anyone know where to get a good deal on an OE style flywheel? I'm not a racer, don't drag, don't need to launch, just use it for commuting. Thanks in advance.
EM2ti
Rep Power: 269 Re: Flywheel source?
You can resurface your flywheel if it's still serviceable. Google the part number 22100-PLR-003 for vendors. There's one on Ebay with free shipping for $120. http://www.ebay.com/itm/200698297369...bile#vi-ilComp
Rep Power: 0 Re: Flywheel source?
Thanks. Other than ebay, an OEM style flywheel seems to be a mystery part on the cheap. Any reason why the service manual says resurfacing is not recommended?
I'm not sure why the service manual would say not to resurface the flywheel. If I remember right it said you must resurface/replace the flywheel in the manual my Exedy clutch came with.
It is possible the flywheel is damaged and cannot be resurfaced but you won't know for sure until you pull it off.
EM2ti
With a new flywheel, you are assured that engagement point is correct. With an improper resurface, you could get everything back together and have the same or new issues. Premature wear, slippage, failure, etc. Not common, but it occurs.
I may get flamed AGAIN for this, but how often do you crack open the tranny? If you are handy and don't mind, by all means resurface your FW. If you are at the mercy of a mechanic, $120 for a new FW vs. $30-60 for a resurface (that may not be 100 percent as good as new), there's not a lot of savings to be had skimping here.
I know every dollar counts, but I'd personally go for the new. If you know of a reputable place or you are a stuggling student, then go with the resurface.
My $.02
Received 1,144 Likes
Rep Power: 485 Re: Flywheel source?
here's an exedy OEM replacement flywheel for $110 @ dezod.
http://www.dezod.com/pd-exedy-oem-fl...5-dxlxexhx.cfm
their shipping prices kinda suck, but the coupon code "7thgenhonda" will alleviate a little bit of that. Dezod's a reputable dealer though. I can personally vouch for them.
grand total (including shipping) to my mom's house in northern cali comes out to $133.47
Thanks all. A new flywheel is going on regardless. For me the cost is negligible, and since the tranny is out, it makes all the sense to throw a new one in. These aren't my younger days where I'm dropping a tranny in an old Chevy truck. FWD cars are a pain, but I'm going to drive this one into the ground.
h4ldol
04-24-2017 08:16 PM
sesi
10-01-2015 02:03 PM
beanhead
09-24-2015 12:04 PM
