Cooling Problem
Rep Power: 0 Cooling Problem
2003 Civic 1.7 SOHC, around thanksgiving did the timing belt,water pump,head gasket,therm,rad cap. Had intermittent cooling problems found it to be a bad water pump. Replaced it last weekend, Today it started again with the temp gauge going up and down stopped and checked for leaks could not see any went 5 more miles down to road with temp in the middle and looked again found the over fill hose had popped off. Maybe need new head gasket, head. I have now idea where to start on this it is making me crazy any help would be great or I might just have to take it to the dealer.
Thanks
Thanks
Re: Cooling Problem
They like blowing head gaskets, they usually breach between the combustion chamber and the water jacket.....Easy to diagnose if one knows what they are dong (IMO).
Make sure to have a reputable machine shop inspect (and correct if necessary) the cylinder head for straightness before reinstallation.
HTH
HTH
Re: Cooling Problem
the overfill hose popping off happened to me once and it was because the overflow tank was clogged so the coolant couldn't expand into the overflow tank and it pop off the overfill hose and blow into the floor. i recommend renting a cooling system pressure tester to test for leaks and a block tester to test for blown head gasket. they rent for free with deposit at autozone and advance
Re: Cooling Problem
FYI, it has been my experience that this doesn't always show the problem.
Applying shop air pressure (160-175+) to each cylinder while watching the coolant level in the taper of a funnel, shows the problem consistently and is definitive proof for me.
Rep Power: 0 Re: Cooling Problem
I will give all these a try. I drove the car for some 300 miles and had no problem. Ran it with the heat on,off defrost,A/C, cound not get the temp gauge to move. Maybe I had a air pocket? I will do some more testing this weekend.
Thanks
Thanks
brian257
06-04-2015 08:17 PM
dinsum
05-28-2015 09:30 PM
