Did I damage my car?
Old 02-29-2012
Nikon123's Avatar
Nikon123 is an unknown quantity at this point
Hi.
I have a 2002 Honda Civic. The mileage now is around 110,000 miles. Recently I drove my car from Chicago
to Texas, total around 1200 miles almost exclusively on the highway. I had some luggage in the trunk,
on back seat and three bicycles at the back of the car. The total weight is around 650 lbs (those are my
weight, luggage and bicycles), not exceed the carrying weight limit of the civic (800 lbs). However, I
noticed that the body of the back was depressed: please look at the attached picture. I had a bad gas
mileage, around 30 mile/gallon in this trip. Normally I get 40 mpg without luggage and attaching bicycle:
that is the combined mileage, including some city driving.
My question is: by put up 650 lbs luggage and three bicycles on the back of the car and drove 1200 miles,
did I somehow damage my car?
I do remember that in the owner manual, it is again to tow a trailer. I am not sure if carrying three
bicycles is the same as towing a trailer?
Thanks.
Dan
ID:	82664   Click image for larger version
ID:	82665   Click image for larger version
ID:	82666   Click image for larger version
Nikon123 is offline
Old 02-29-2012
POQbum's Avatar
POQbum can only hope to improve
Re: Did I damage my car?
From the pic it looks like you still have a bunch of stuff in your rear seat and probably trunk that is making it still depressed, right? If you take all of it out and it levels out then I don't think you have anything to worry about- unless you ran over a pothole or speed bumps really quick and your tire hit against the inside body of your car, that would probably do some damage.
POQbum is offline
Old 02-29-2012
got2run5's Avatar
got2run5 will become famous soon enoughgot2run5 will become famous soon enough
Well, the back end is going to go further down when you add weight to it. If it doesn't go back up again after you get rid of the weight you probably need new struts.
got2run5 is offline
Old 03-01-2012
sl33pyriceboi's Avatar
the worst thing u could have done is blow out ur shocks, which are replaceable...
weighing down the car so much, traveling 1200miles, and already having 110,000 miles will take a toll on ur rear shocks.
sl33pyriceboi is offline
Old 03-01-2012
Received 1,437 Likes on 1,193 Posts
i did same.
Quebec to TN, full of stuff. Only difference was that i have springs and shocks aftermarket.
Mine was even lower than that. After removing all the stuff, it came back up just fine.
Like mentioned above, if you hit bumps too fast you could have hit the bumpstops too many, too much and shocks might leak if seals are broken. IF. Not "I am sure of it". It's an IF.
The mileage is because the bikes are not what you would call aerodynamic...
sdaidoji is offline
Old 03-01-2012
EM2ti
maxtierney's Avatar
Agree
maxtierney is offline
Old 03-01-2012
Nikon123's Avatar
Hi. Guys:
Thank you all for the replys. After I took out every thing (bicycles, stuff in the trunk and on the back seat). The rear body of the car rise back to normal. I checked the real shock and it is good. What I mean 'good' is that I pushed down the rear end and the rear end bounced back without going up and down.
Again, thanks for everyone. I plan to run my little civic to the ground (at least to 200,000 miles). I changed the timing belt last summer while the mileage was around 100,000 miles.
Dan
Nikon123 is offline
Old 03-02-2012
Gangsta Sexy
FordSlayer's Avatar
FordSlayer is an unknown quantity at this point
ive had 1400 pounds of lead in my car. no problems.
FordSlayer is offline
Xuhme
21
08-07-2023 03:40 PM
CarStuff
12-06-2020 12:52 PM
mattdoc
03-14-2017 12:10 PM
usajags84
15
08-19-2015 03:12 AM
Gunner
Engine DIY
10-06-2012 12:37 PM
Quick Reply: Did I damage my car?
