interior LEDs
Old 01-25-2012
paulymcd7's Avatar
paulymcd7 is an unknown quantity at this point
interior LEDs
i just got LED strips from advanced auto. how do i wire them up to turn on with a switch i got? fuse tap?
paulymcd7 is offline
Old 01-25-2012
paulymcd7's Avatar
Re: interior LEDs
also how could i set it up to turn it on with a switch as well as it turning on with the dome light
Old 01-25-2012
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner's Avatar
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
Re: interior LEDs
You can get a fuse tap..and hook it up to a fuse spot that turns on when you want it to..
wire the the power wire for the switch to the fuse box,
the power wire of the lights to the switch..
and ground the lights to the chasis somewhere..the switch and light grounds should be seperate..
If you need more detail let me know, or do a search.
Gunner is offline
SammySC
121
04-07-2017 07:43 PM
cferry7
10-18-2015 06:32 PM
frank_kleng
09-29-2015 10:55 PM
dhuff
09-28-2015 08:35 PM
Dsmak
09-22-2015 05:16 PM
Quick Reply: interior LEDs
