Cars Missing Front Stabilizer Bar.. What do i need?
Rep Power: 0 Cars Missing Front Stabilizer Bar.. What do i need?
i bought my car about a year ago, (2004 hond civic vp coupe)
i currently have slight suspension modifications to it such as eibach pro springs and front upper strut brace. i noticed while my car was up on a lift that the front stabilizer bar and all the componets of the assembly (links ect.) are missing, i have no idea what i need to buy or where to get it. i dont have alot of money to spend so i was looking to get something used stock or after market. i havent seen one single thing on line that has the entire assembly and to be honest i dont know what or how many parts i need, any help is apreciated but please keep in mind i dont have alot of money to spend.
thanks
thanks
Live for the Twisties
Rep Power: 260 Re: Cars Missing Front Stabilizer Bar.. What do i need?
You're fine without a front sway bar, removing it is a very popular modification among all tuners who work on front wheel drive cars.
Front sway bar causes understeer, understeer is a joy killer, oversteer is more desireable. Increases roll in corners means you'll have lower entrance speeds, but the increased traction that results from the roll will give higher exit speeds.
Received 1,442 Likes
Rep Power: 338 Re: Cars Missing Front Stabilizer Bar.. What do i need?
I unhooked mine front sometimes when autoX. weird and sometimes unconfortable at transitions, but the timer said otherwise. 1 sec gain in a 70 sec course, which is a lot.
yeh will not feel that much since the springs are stiffer.
i am now keeping mine hooked because i have the larger rear progress bar and running -1.5/-0.5 camber F/R
Rep Power: 0 Re: Cars Missing Front Stabilizer Bar.. What do i need?
Thanks ive herd that to but I think because my car is a daily driver and I alrdy did light suspension modifications I mite enjoi the ride beter with it installed. Would anyone mind please listing all the parts links and hardware id need to get one and mayb where I could find one
In that case, just go to a junk yard, it should be less than $100.
You can use an RSX or Civic bar, but I would try to get the smallest bar possible, which would be from an 03-05 Civic.
You need the brackets, bar and endlinks.
Rep Power: 210 Re: Cars Missing Front Stabilizer Bar.. What do i need?
As an example you need numbers 5, 8, 9, 6 (2), 7 (2), 16 (2), 18 (2), and 23 (2): http://www.hondapartscheap.com/index...ponent=KNUCKLE You can get used numbers 5 and 7 but, recommend you buy everything else new.
Figure I should follow up. Yesterday I bought the stabilizer bar and all the hardware from member- 04 honda civic- just installed it today and I gota say im happy with my decision to do so. Car feels much tighter threw the turns and over all more stable..go figure..lol anway just figured id follow up thanks again everyone who helped
cooldan1
04-23-2015 10:49 AM
GH04si
04-15-2015 08:13 PM
usajags84
04-10-2015 09:54 PM
