"Small Light" fuse keeps blowing - Honda Civic Forum
7th Generation Civic In the years from 2001 to 2005 Honda released it's 7th Generation Civic. Chassis codes: EM2, ES1, EP3, EU1
LinkBack Thread Tools Search this Thread
Old 11-02-2011   #1
Busy Speeding!!
SlimRisk's Avatar
SlimRisk is a jewel in the roughSlimRisk is a jewel in the roughSlimRisk is a jewel in the rough
Okay so the other day I noticed my tail lights and my gauges didnt light up anymore. (the brake lights, turn signals, head lights, and the srs, cel etc. all work fine)
Did some heavy duty searching and most people say the "small light" fuse has blown. checked it today, and yep, blown. This is the 3rd one ive gone through.
Most people said that you need to disconnect the dimmer positive and illumination (orange wires) going to your head unit. Mine have always been disconnected with a protective boot on the end so they dont ground. What could be causing this fuse to blow?
SlimRisk is offline   Reply With Quote
Old 11-02-2011   #2
25+ Years Driving Japanese Automobiles
CraigW's Avatar
Re: "Small Light" fuse keeps blowing
Does the fuse blow the second the lights are switched on ??
There are 2 wires leading to the head unit that could cause problems. The FACTORY colors are (1) RED/BLK Pin A9 it comes directly from the fuse you are replacing,same as is used for markers,tails & licence lights. (2) RED Pin A19 it is for the dimmable bulbs.
See if wires leading to these 2 are connected or need isolated.
Let us know when the fuse opens that will help some.
CraigW is offline   Reply With Quote
Old 11-02-2011   #3
Busy Speeding!!
SlimRisk's Avatar
Both comming from the car to the headunit are not connected to the hu and are isolated. On my 01 lx they are orange and orange/white for dimmer and illuminator. Ill take out the gauges tomorrow and look at the circuit board.
Thread Thread Starter Honda Civic Forum Replies Last Post
2002 Civic EX Head Gasket Help!!!! Kyles24 Mechanical Problems/Vehicle Issues and Fix-it Forum 0 07-12-2015 10:15 PM
Smoother A/T Shifts Through TPS Adjusment and More? turd_ferguson Mechanical Problems/Vehicle Issues and Fix-it Forum 8 07-12-2015 12:54 PM
Cabin Blower Motor / Fan " Repair " !!! ZILLA Mechanical Problems/Vehicle Issues and Fix-it Forum 1 07-11-2015 09:35 PM
Stuck in park. Brake Lights Don't Work. Horn Does Not Work. JustaRhymez Mechanical Problems/Vehicle Issues and Fix-it Forum 8 07-10-2015 08:12 AM
1994 Civic pcv hoses silentz 1st - 5th Generation Civic 8 07-09-2015 09:16 PM
Tags
07, 1990, 2001, blowing, civic, daylightfusekeepsblowing, exterior, fuse, honda, light, lights, marker, pilot, small, tail
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
All Content Copyright 2007 CivicForums.com
