NOT Solved: Vacuum Leak When Accelerating?
Busy Speeding!!
1 Post
Rep Power: 169 NOT Solved: Vacuum Leak When Accelerating?
Hey guys I started my car up today and it was idling fine, and I wanted to rev it up, but as soon as it gets to 2000 rpm it starts reving up and down. Im pretty sure its a vacuum leak. Why would it only leak when I accelerate? and would gas/starting fluid work to find it?
Rep Power: 787 Re: Vacuum Leak When Accelerating?
could be air is moving slow enough at idle that it bypasses the torn hose without escaping.
Rep Power: 210 Re: Vacuum Leak When Accelerating?
I usually use carb cleaner. Pretty much whatever is on hand. *Wouldn't recommend gas.
Take off the air filter housing and check the throttlebody gasket real good with the carb cleaner. Remember small, controlled squirts.
***AND FOR GOD'S SAKE DON'T SPRAY ANY ON THE EXHAUST MANIFOLD***
Busy Speeding!!
1 Post
Rep Power: 169 Re: Vacuum Leak When Accelerating?
Solved! Tightened down all hoses and clamps and no bouncing revs.
EDIT: NOT SOLVED
I think it could possibly be from knife-edging my throttle plate. any suggestions?
EDIT: NOT SOLVED
alxz310
07-30-2015 12:18 PM
Causemo
07-05-2015 06:42 AM
Causemo
07-04-2015 07:11 AM
