Removing the air intake resonator
Rep Power: 0 Removing the air intake resonator
Ha! Little problem - how do I detach the harness attached to the bottom of the air intake resonator. I took out the 4 bolts and lifted the resonator, then noticed the harness attached to the bottom. I could not see under there, and felt around a bit, but could not figure out how to detach the harness. Thanks!
Re: Removing the air intake resonator
Alright, well I don't know if you're talking about the same thing that I'm thinking, but if you are...
When we installed a CAI into my EM2 we ran into a similar problem. We took out the four bolts and still couldn't pull the resonator out. Until we figured out that you have to pull that rubber pipe thingy (sorry... I'm not good on technical terms ...) out of the resonator. It holds it in there pretty well, and we just kinda wrestled it out of its housing, and the next thing we know the resonator came out.
I know my answer was vague, and it may not even pertain to your question. But I hope I could help.
Rep Power: 0 Re: Removing the air intake resonator
Like... it wasn't the air intake duct. It was like between the box where the air filter is located and the box where the air intake is at. I'm sorry my descriptions suck, I'm just not good with the automotive lingo.
Prelude Owner
http://www.injen.com/galleries/produ...7_05192009.pdf
These are the instructions I used for my install. They might help.
ORskier
05-07-2015 04:54 PM
Hobby2K
Bolt-on Engine Performance
11-09-2001 04:08 PM
