Sponsored by:
Sponsored by: DashLynx
2003 Civic EX Overheating...still
Old 10-24-2011
queenb592's Avatar
queenb592 is an unknown quantity at this point
I've been battling this overheating issue for almost 2 years. Every component in the heating and cooling system has been replaced...some at least 3 times (water pump, thermostat...) and I'm back at the same issue again. When I am idle it begins to overheat. And now that it's getting colder, when I turn the heat on, 1), it doesn't immediately warm up (tale, tale sign) and 2) that will cause it to overheat while I am driving. I'm not sure what else to do. Or what else it could be. I just spent nearly $1000 having the head gaskets replaced...One of the reasons I was adamant about getting a Honda was that I knew if took care it, it would take care of me...so far not seeing that! HELP!
queenb592 is offline
Old 10-24-2011
ac_2007's Avatar
ac_2007 will become famous soon enough
Re: 2003 Civic EX Overheating...still
Did you machine the head and torque everything by the book when doing the headgasket? If not, that is your problem.
ac_2007 is offline
Old 10-25-2011
is it losing coolant? did you use oem cooling system parts?
gearbox is offline
Old 10-25-2011
Live for the Twisties
MindBomber's Avatar
Have the hydrocarbon levels in the radiator tested, to confirm whether it's the head gasket or not with complete certainty. The kit to do so can be rented at autozone.
MindBomber is offline
Poopies
04-20-2017 11:36 PM
usajags84
05-10-2015 08:11 AM
Ian SFBA
Interior DIY
04-25-2015 02:25 PM
Fastfebur
04-22-2015 01:37 PM
deus-ex
04-13-2015 12:29 PM
Quick Reply: 2003 Civic EX Overheating...still
