Hi, am I getting ripped off?
Rep Power: 0 Hi, am I getting ripped off?
So I got an estimate today for new tires along with a timing belt and such, here is all the information you need to know:
https://i.imgur.com/XoR7Y.jpg
Am I getting ripped off? Can't I just buy tires and put them on one by one myself? Then go somewhere and get an alignment?
Also, how hard is it to replace the timing belt and water hose? I don't know much about cars, but thanks to a guide on this forum my roomate and I managed to replace the window regulator and motor (came as one unit) on the drivers side door.
Received 1,146 Likes
Rep Power: 485 Re: Hi, am I getting ripped off?
Timing belt isnt terribly hard, just rather intrusive, and we have a few great DIY guides.. But, if you are having someone do the work for you, that sounds about right.. Maybe a tad on the high end..
I recently bought tires, and that alone ran me $600, and a dealership quoted me $650 for a timig belt job.. I did the timing belt myself and saved hella money.
$300 to change 2 radiator hoses is outrageous. It literally takes 20 minutes, $11.99 for the upper hose and $14.99 for the lower at Oriley.
I also love how they say our cooling system needs 3 gallons of anti freeze, more like 1.1.
The timing belt install is about right, I'd call the dealer and ask them for a quote, if it's about the same you should have them do it.
Or you could do it yourself. I just did mine for the first time a couple weeks ago and it wasn't all that bad, just a tight working area. The DIY's are great. It would be about $120 in parts w/out tensioner, $170 w/tensioner. That's if you go with Honda parts.
I used Dayco parts and spent $120 for timing belt/tensioner/water pump/accessory belts.
You could always get the tires off Tirerack and save a bit of money. Research them too, bad tires are annoying!
Definitely do the timing belt and water pump yourself. Like others have said, it's not very difficult and there's tons of DIY guides to help you. Just take things slow, remember the order you remove parts, and get your T.D.C marks lined up.
The hardest part I found was getting the stupid crank pulley bolt off. The rest really is just removing and reinstalling parts. I also made a very stupid mistake of not plugging in two of the four coil packs! Let's just say, I almost shat myself when I started the car
Rep Power: 0 Re: Hi, am I getting ripped off?
Any good goto books or DIY's on replacing a timing belt and water pump? Seems very complicated, especially for someone who knows next to nothing about cars.
Prelude Owner
Rep Power: 174 Re: Hi, am I getting ripped off?
Did you really get charged $300 for coolant, recycled anti-freeze, and two hoses? lol
It's in the right price range, but like riceboy said it's a little on the high end side. When i bought my car the guy showed me the receipt when he did the timing belt and water pump and it came to like $750.
alinaray
18
08-24-2015 01:04 PM
bluedoggy1
06-20-2015 11:25 PM
blowhole
03-20-2002 08:43 PM
