And the Sh*t hits the fan...or clutch
Well, I finally had the dreaded gears popping out on my 03 5spd. It happened when I was 50 miles outside of where Im going to college (6.5 hours from home.) It really sucks limping into town in 4th gear at 75 mph on the highway. I sucked it up, and knew I would have to spend the money to get it fixed. I had finally comes terms with what happened, when all of a sudden yesterday, i was backing out of my parking spot, when i hit the friction point, and something dropped. Its like my clutch completely gave out. My vic will stay in gear, and shift into gear even with the clutch out all the way. It also makes a nasty grinding sound whenever its at idle. I dont even know what to think right now. Im more than mad. So for now, im stuck 6.5 hours from home with a non-running civic. I think i really needed to vent about all of this. Im just so frustrated right now. Being a college kid, I really am not looking forward to dropping alot of money to get my car going again.
Live for the Twisties
Rep Power: 260 Re: And the Sh*t hits the fan...or clutch
Man, that sucks.
I know exactly how you feel, but at least it happened now before school starts getting really busy.
Rep Power: 0 Re: And the Sh*t hits the fan...or clutch
It is too bad you didn't bother replacing it before it completely gave way had you done that it probably would be a cheaper fix you now may need to replace the flywheel. If you are doing it now do it right put a good quality clutch and if you spend the money u mind as well put a lightened flywheel in you are looking at at least 300-600 in parts depending on what is wrong and about 4-8 hours labor depending on the shop 350-800. If you do it yourself it will take you probably ten hours if you do it my way. Pull the tranny from the top side by removing the thermostat housing/egr housing or you can do the job with it in the car by supporting it from the top and splitting it about 4-6 inches apart this way is harder on u but faster.
$275 clutch
$50 flywell resurfacing
$50 fluid
$400-800 for a trans rebuild - A few possibilities come to mind, but I my diagnosis would be pretty rough.
$500 for dropping the trans and re-installing.
Rep Power: 190 Re: And the Sh*t hits the fan...or clutch
i just replaced my trans and i picked up a fully rebuilt trans for $350, stage 1 clutch for $220, and $250 for 11lbs flywheel. got it all installed for $400.. prices are in cdn btw
well, car has been fixed for a few weeks now, and everything was going good until today. I had my transmission rebuilt and a new clutch put in. I shifted into 4th, when I felt a pop and lost all power to the wheels. I pulled over, and saw my transmission leaking fluid profusely. Right now its at the repair shop. I'm just so fed up with this crap. If I wasnt a student right now, I would probably trade in my car by now, or part it out.
Received 1,440 Likes
Rep Power: 338 Re: And the Sh*t hits the fan...or clutch
ouch!
the driveshaft maybe was not fully in?
yes, the driveshaft need to be pushed all the way in to have the seals ... seal the oil inside.
however, that would make the oil leak slowly, so you might have had a small puddle under the car. if that was not the case, something else could have had blown during use.
but that is about the fluid leaking. i guess it's too early to pinpoint that as the reason of the failure.
wait for the diagnosis from the shop, right now just try to get some sleep
mrohitredd
40
09-09-2017 12:03 PM
mjdiaz89
06-21-2016 09:26 PM
adamdrives
15
08-08-2015 08:53 PM
Roman Rembacz
07-16-2015 12:30 PM
