2004 Honda Civic EX Signal Lights Problem?
Old 09-08-2011
Omidgooz's Avatar
Omidgooz is an unknown quantity at this point
The signal lights flash for 3 seconds than it turns The warning lights flash few second longer maybe 5 seconds all together and than that turns off. I have checked and tested all fuses and they are fully functional. The ticking also stops once the lights stop blinking. What could be the problem????
Omidgooz is offline
Old 09-08-2011
lazlong's Avatar
Re: 2004 Honda Civic EX Signal Lights Problem?
Download the manual and do the combination switch input test. Chances are the combination switch is bad. The combination switch is on the end of the actual piece you use to turn the turn signal on, inside the steering column cover.
https://www.civicforums.com/forums/1...e-updated.html
lazlong is offline
jessicakaybby
04-20-2015 12:11 PM
ashleymmackey
04-18-2015 09:48 PM
chgofirefighter
04-18-2015 08:08 PM
dooner24
04-14-2015 07:51 PM
Quick Reply: 2004 Honda Civic EX Signal Lights Problem?
