Sponsored by:
Sponsored by: DashLynx
hood wont close!!!
Old 07-22-2011
ke2
ke2's Avatar
ke2 is an unknown quantity at this point
hood wont close!!!
i just bought a 2002 civic LX, and noticed that the latch works, but the hood wont close all the way. i dont need to "pop" the hood to open it, just need to unlatch it and.. the bungee cord thing thats kinda holding it together. anyone know if i need to replace the whole hood or is this a simple problem i can fix on my own? thx
ke2 is offline
Old 07-22-2011
Re: hood wont close!!!
could just be it needs a new latch assembly
gearbox is offline
Old 07-23-2011
lazlong's Avatar
It's number 5: http://www.hondapartscheap.com/south...t=0&quantity=0
BTW: Can anybody identify numbers 41-43? They're not listed on any 7th gen parts list on 3 different sites.
lazlong is offline
Old 07-23-2011
usually when they have an inlay its for a different trim or model. they do that a lot when you look up parts for an EX for example and it will have the LX parts in a box like that even tho it doesnt list them in the parts list (unless you look up the LX instead).
gearbox is offline
Old 07-23-2011
02 coupe DX
Lopes101's Avatar
Lopes101 is an unknown quantity at this point
before you try to change anything, the hood pop handle in the car, after you pull it to pop it, press it all the way in. Literally after pulling it, PUSH it in. My hood does that, and for 2 months I drove around and almost brought it to the dealer! because nobody could figure it out. would have cost my a fortune. So for sure try that first.
Lopes101 is offline
Old 07-23-2011
lazlong's Avatar
I know this but, I searched every trim and year (takes me about 12 minutes now. lol) and it's not listed for any model.
lazlong is offline
Old 07-23-2011
lazlong's Avatar
Good call. Did you ever fix it properly? If so, what was the culprit? The latch or the cable?
lazlong is offline
Old 07-23-2011
02 coupe DX
Lopes101's Avatar
nope, havent fixed it yet, whenever i pull the hood latch i just push it back in place everytime. my trunk and gas tank latch does the same, push it down gotta pull it up, pull it up gotta push it back down.
Lopes101 is offline
Old 07-23-2011
lazlong maybe its a canadian or other car part kinda looks like a hood latch with sensor to tell you when its open like the trunk.
gearbox is offline
Old 07-25-2011
army12bc's Avatar
army12bc will become famous soon enough
i had similiar problem, couldnt figure it out and then ended up ripping plastic handle from the hood cable (inside) after putting cf hood on i noticed the latch actually pulled itself through the rad support metal. had to drill latch out and put bigger bolt through it with washers.
army12bc is offline
SammySC
121
04-07-2017 07:43 PM
UltraHDGames
06-08-2016 05:16 PM
Bikergofast
Detailing
11-20-2015 02:34 PM
rnaodm
09-21-2015 12:42 PM
AyyeeGeorgee
09-14-2015 12:54 PM
Quick Reply: hood wont close!!!
