Worth the cash?
Rep Power: 0 Re: Worth the cash?
I would reccomend the using the search button because topics like this and what intake should I get ( which you will probably ask sometime in the near future ) have been covered more then enough times . And you have to pay to play if you want to actually improve your car a little get the full cat but if you want to look and sound like a douche get a cheap muffler it's really all up to you.
Rep Power: 174 Re: Worth the cash?
Live for the Twisties
Rep Power: 260 Re: Worth the cash?
Without getting a header to tip exhaust it's impossible to make any actual gains, but i will sound nice with a cat back. If you want to get just a muffler go for it, but it will sound like garbage and that's the epitomy of rice.
So a cat back system gives you no gains? It advertises a 4 to 5 hp gain? I am not arguing ....just wondering
So from the end of your reply I understand if you dont do the whole exhaust it will sound bad.
Received 1,440 Likes
Little Fish
They always advertise over the top to try & drum up sales. They always use the larger number, which translates to the crankshaft. The parasitic loss from drivetrain drag and torque transfter is usually 15 to 30%. So in actuality, you'll only see barely a 1 hp increase at the wheels. Not worth the money, IMO. The only thing with adding a cat back is exhaust sound level and note change, which does give the perception of an increase in performance because you can hear the motor more, giving you the impression it's got more power. Translation = "it's in your mind". If you want a definite noticeable increase in output, it's gonna cost ya an intake and full header and exhaust. The rule of thumb with modifying is you have to "go with the flow", so in order to support a larger, free-er flowing exhaust, you must open up the intake to match. A good word to say would be to "un-cork" it. Wouldn't hurt to put a hotter coil pack too. That's a more expesive route, but it will get you a noticeable increase in power, where only a cat-back exhaust will not.
I used to build engines in the mid-late 90's, mainly big block Mopars and Corvette Small Blocks. My finest motor was a 440 Police motor pumping 894 HP/725 Ft Lbs. on pump gas. Good lord were those BB Mopars LOUD! My Most memorable Small Block was a '79 L-82 Corvette. I cut a "Ram-Air" hole in the hood directly in front of the intake tunnel. Punch that sucker at freeway speeds, and it was like a supercharger kicking in, bigtime! These days in the name of economy, I have gone the way of the "Spice Rice"
^There's really no need to upgrade the coils on a D17, the stock ones are plenty powerful for basically any level of modification. They're one of the few things on our engines that doesn't need to be changed out.
jackoncruzpr
09-29-2015 07:59 PM
beanhead
09-24-2015 12:04 PM
Touge
09-22-2015 11:55 PM
Touge
Ottawa
09-22-2015 11:52 PM
Touge
09-22-2015 11:52 PM
