OEM Coupe Lip on Sedan...
Rep Power: 0 OEM Coupe Lip on Sedan...
So I've heard that the 2001 OEM coupe lip can be installed on an 01 sedan. Is this true? and what has to be done so that it fits properly?
Rep Power: 787 Re: OEM Coupe Lip on Sedan...
its true. some new screw holes on the rear lip bottom for better support is recommended. everything else is screw on except the sideskirt mounts which are stick on (make sure you clean the paint with alcohol, apply the stick mounts, wait overnight for the adhesive to cure, then bolt the skirt on).
Rep Power: 0 Re: OEM Coupe Lip on Sedan...
Wow ok Sweet. This is the lip i'll probly order from handa-accessories.com http://handa-accessories.com/civic/civfus01.jpg. And does anybody know if the lower grillcraft grille will still work with front lip kit?
it should, considering the lip fits over the oem bumper. so you still have the same hole and everything.
hayden55
07-08-2015 11:38 PM
hatch90
07-05-2015 01:17 AM
