2nd Gear Grinding... new clutch?
Old 05-12-2011
got2run5's Avatar
got2run5 will become famous soon enoughgot2run5 will become famous soon enough
Alright, so recently my second gear has been really really easy to grind. I literally have to push the clutch pedal all the way to the floor, and take time to put it into second if I don't want it to grind. Mechanics have told me my clutch needs to be replaced very soon (original with 150xxx miles). Problem is... I'm not sure if the clutch is causing this or if something else is wrong. Any ideas?
Old 05-12-2011
Trance Addict
MelJ's Avatar
Re: 2nd Gear Grinding... new clutch?
Could be the synchro. Are the revs shooting up in higher gears(slipping).
And fyi, you should be flooring the clutch for every shift .
Old 05-12-2011
got2run5's Avatar
No they don't shoot up at all. I don't have a lot of knowledge about this stuff so that's why I'm asking. It's just obnoxiously easy to grind second gear and I don't want to replace my clutch and have the problem persist. So you really think it's the synchros?
Old 05-12-2011
Trance Addict
MelJ's Avatar
You can try switching to a synthetic gear oil like Redline or Amsoil to see if it helps any. You can also try double clutching into 2nd, or just skip 2nd gear altogether and go straight to 3rd. You'll have to wind 1st out a little more, but it may help.
Old 05-12-2011
got2run5's Avatar
Yeah I actually have been double clutching a bit when I down shift around corners. I want the car to last for a while longer though so I'm thinking I'm going to get whatever fixed that needs fixing. I'm just looking to diagnose what needs to be done and finding roundabout how much it's going to cost :/
Old 05-12-2011
2002ExCivic's Avatar
2002ExCivic has a spectacular aura about2002ExCivic has a spectacular aura about
youll learn to deal with it. i did. lol just shift smoother.
Old 05-12-2011
got2run5's Avatar
So was it a problem on yours or is it normal for 2nd to be a pain?
Old 05-12-2011
Muirsy's Avatar
Muirsy is a jewel in the roughMuirsy is a jewel in the roughMuirsy is a jewel in the roughMuirsy is a jewel in the rough
its prob the synchro thats causing 2nd to grind
Old 05-12-2011
Trance Addict
MelJ's Avatar
2nd gear takes A LOT of abuse and is probably the most used gear. It has a pretty decent range, and people usually f up shifts there. Like I said before, you need to make sure you're flooring the clutch. I learned standard on my Si and I had a few grinds into 2nd and I learned quick. It isn't a pleasant feeling or sound. I've only driven my car for 2 years, but I can make it so the shifter literally just slides right into 2nd now. Time your shifting a little better and that may also work like 2002 said.
Old 10-07-2019
Tracecross30's Avatar
Tracecross30 is an unknown quantity at this point
I have a 02 civic ex and i rebuild the tranny and from that point until now, i having grinding issues with 2nd, 4th and so . i was thinking i should reuse the oil that i drained from the tranny.i heard about mobile one transmission oil works good ,Amsoil as well..i will try amsoil.my synchros are find ,i dont see any reason to replace them or any gears..
threeoten
Transmission
12-10-2015 11:08 PM
Deception2k1civic
08-28-2007 10:02 PM
Angry_Angel
Arizona
11-19-2005 12:28 PM
Jrfish007
09-24-2005 12:34 PM
Tyler
11-16-2002 10:59 PM
Quick Reply: 2nd Gear Grinding... new clutch?
