Front hub removal?
Rep Power: 0 Front hub removal?
About a week ago i discovered that i have a stripped lug nut stud on my front drivers tire. I decided to take the car to a local shop to have the stud replaced. But to my disappointment they seem to have "fixed" the stud and gave it a lug nut that will only work on that stud. when i took it off there were metal shavings all over it.
As you would imagine i am extremely aggravated, i guess thats why i usually try to do everything myself (like replacing my alternator earlier this week). So im going to have to deal with that shop on my own time but i was wondering if somebody would be able to explain the process of removing the hub on my 2004 LX so i can hammer a new stud in there. I got as far as removing the brakes and rotor.
Thanks a lot!! (and i promise to make a nice little write-up of what i did, including pictures)
Whachya lookin at?
Rep Power: 289 Re: Front hub removal?
I made a ball joint DIY that will help you remove the knuckle, I'm pretty sure you have to remove the knuckle to remove the stud... After that I believe they are pressed in so getting it out is a bit of a PITA but definitely doable.
https://www.civicforums.com/forums/1...necessary.html
I'd check the Honda manual for you but I'm late for work!!!
Live for the Twisties
Rep Power: 260 Re: Front hub removal?
Unfortunately, you can't hammer the stud out on our model civic while the hub is still on the car. You need to remove the hub from the car and separate it, then you could set it on a couple wood blocks, hammer the stripped stud out and pull a new one in.
Received 1,440 Likes
Rep Power: 338 Re: Front hub removal?
here
https://www.civicforums.com/forums/7...mage-help.html
and just in case, but this is a 6th gen and the thing being pressed in is a bushing, but same process.
Rep Power: 210 Re: Front hub removal?
To the OP: Hammer the stud in as far as you can, put everything back together, put the wheel on and tighten it until the stud seats.
To everyone else: Don't harp on me for my shadetree tricks. I've done it this way dozens of times with no problem. You know who I'm talkin to. lol
Supramk3
06-11-2015 11:13 AM
