New struts now steering wheel off center? - Honda Civic Forum
7th Generation Civic In the years from 2001 to 2005 Honda released it's 7th Generation Civic. Chassis codes: EM2, ES1, EP3, EU1
LinkBack Thread Tools Search this Thread
Old 04-14-2011   #1
specialized7 is an unknown quantity at this point
Hey guys, Yesterday i decided to rip into the civic.
I Bought a set of OEM springs as well as cheap struts to replace the lowering springs and blown struts on my car.
So anyways All goes well tie rods come out easy everything went smooth. I even changed my one caliper and an 02 sensor.
But now my steering wheel is quite off center , id say a little less then quarter turn?
its not driving weird or anything just steering wheel is off center?
will an alighnment fix this?
anyone had this happen before?
Opinions?
specialized7 is offline   Reply With Quote
Old 04-14-2011   #2
Administrative Rice. WAT?!
xRiCeBoYx has much to be proud ofxRiCeBoYx has much to be proud ofxRiCeBoYx has much to be proud ofxRiCeBoYx has much to be proud ofxRiCeBoYx has much to be proud ofxRiCeBoYx has much to be proud ofxRiCeBoYx has much to be proud ofxRiCeBoYx has much to be proud ofxRiCeBoYx has much to be proud ofxRiCeBoYx has much to be proud ofxRiCeBoYx has much to be proud of
Re: New struts now steering wheel off center?
Get an alignment. If that doesn't fix it, post back up
xRiCeBoYx is offline   Reply With Quote
Old 04-14-2011   #3
Super Moderator
sdaidoji is a splendid one to beholdsdaidoji is a splendid one to beholdsdaidoji is a splendid one to beholdsdaidoji is a splendid one to beholdsdaidoji is a splendid one to beholdsdaidoji is a splendid one to beholdsdaidoji is a splendid one to beholdsdaidoji is a splendid one to beholdsdaidoji is a splendid one to beholdsdaidoji is a splendid one to beholdsdaidoji is a splendid one to behold
tie-rods were not any good anymore, but now you have good ones and need to adjust steering to them.
sdaidoji is offline   Reply With Quote
Old 04-14-2011   #4
bigheadmark is an unknown quantity at this point
I would look up the DYI as far as tie rod ends...on this forum and even on youtube...there are tricks/tips you need to adhere to when replacing tie rod ends...ie, placing a piece of tape and marking where the tie rod end originally was BEFORE you remove it, that way you know how far to screw in the new one....also, another trick, is, if the new tie rod ends are the same as the ones on your car, make sure you count the number of turns when you remove the old ones, then repeat the number of turns when you install the new ones....for example, i just replaced my tie rod ends....the passenger side came off with 11 turns....i made sure i screwed the new one in 11 turns.
bigheadmark is offline   Reply With Quote
Old 04-14-2011   #5
Sorry for the confusion but I didnt change tie rod ends, just knocked them out of the Strut assembly .
one more question: after some research about my problem i came across someone saying how you can hear a banging in the from when hitin the gas in first gear.
I think my lower control arms and buggered or at least the bushings. Are they replaceable?
Old 04-14-2011   #6
My alignment always goes out of whack when i separate tie rods. That said, evey time I mess with my suspension, I get an alignment immediately afterward.
As for your banging noise, I'd make sure everything's tightened properly first.
Old 04-14-2011   #7
Super Moderator
Quote:
before going heads on, inspect them, if they look bad, read this. or just read this and inspect them to see if they look the same. (PS: it's linked in one of the links in my sig, BTW)
DIY: repair Lower Control Arm broken bushings
Old 04-14-2011   #8
THANKS! they look exactly like that both of them are completely broken out i can smack them back and forth .
im going to do that. Thanks for the DIY.
im thinking an alighments is all i need for the none straight steering because i mean the car is 2" higher now so things are out of wack
Thread Thread Starter Honda Civic Forum Replies Last Post
Alignment/steering wheel issue. honda200192 7th Generation Civic 7 05-31-2015 05:57 PM
Cannot adjust toe tomg Mechanical Problems/Vehicle Issues and Fix-it Forum 3 05-21-2015 07:05 AM
honda civic 2004 steering wheel noise anddrrey Mechanical Problems/Vehicle Issues and Fix-it Forum 4 05-11-2015 02:30 PM
2009 grinding noise when turning in both directions edgenet 8th & 9th Generation Civic 1 05-02-2015 08:00 PM
HELP! me honda has no power! Switch BL4D3 I.C.E. & Electrical 23 04-24-2015 06:57 PM
Tags
03, 2004, badge, center, civic, crooked, es1, honda, motion, replaced, replacing, sensor, steering, struts, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All Content Copyright 2007 CivicForums.com
