What Clutch & Flywheel
Rep Power: 0 What Clutch & Flywheel
Hi there,
I'm needing to replace my clutch in my 03 civic d17a1. Wondering what is a good brand clutch for these cars? I only have header, cai, and high flow exhaust w/o cat or resinator. I do drive my car like a race car once in a while even though I know its not that fast.
Would I benefit from a stage 2 clutch and lighter flywheel? Suggestions are greatly appreciated!
TIA!
Chad
TIA!
Chad
Live for the Twisties
Rep Power: 260 Re: What Clutch & Flywheel
A light weight fly wheel is a huge benefit, it reduces weight directly at the crank and that's where it really counts unlike silly carbon fiber hoods and seats. It give a nice little bump through the entire power band, but especially in low rpms as your accelerating.
Rep Power: 0 Re: What Clutch & Flywheel
So what would be a good flywheel and clutch to go with then? I have no idea what the stock flywheel weight is. Is there any downside to a lighter flywheel like longevity?
Received 1,440 Likes
Rep Power: 338 Re: What Clutch & Flywheel
the mass of the flywheel is suppoed to keep engine from changing its momentum. If it is spinning, it will tend to keep spinning.
reducing the mass will:
1) make rev up or down easier, so acc will be better.
2) coasting will drop, some hill climb will require more gas to keep going up.
Longevity - there is enough metal there, no changes.
Stage 2 might be too much if no power adder like turbos or nitros. will make heavy pedal
find stage 1 and some not much reduction flywheel. you will thank that on a traffic jam.
Right now i have the ZOOM RACING flywheel that is 7lbs zoom is the same company as Fadanza u can get it at www.summitracing.com the cost is about $275 and the Exedy stage 1 you can get at www.passwordjdm.com but where i got my stage 2 Exedy 3 puck ceramic was ebay and that was about $500 plus tax hope this helps (note that the stage 2 will shimmer a little on take off due to the 3 pucks)
7lbs? that is light...
thanks for the stock weight numbers, that gives more insight
Oh, yeah, i just found this:
some info on clutch/flywheel
http://www.xproductionz.com/forum/showthread.php?t=948
The factory flywheel is about 20lbs from what i can remember. i dont have any problems in stop and go traffic and ive had it for about 3yrs. Basic bolt ons i would go with the stage 1 to as sdaidoji sujested the only reasion i went stage 2 is begause of the cam
Hi there,
TIA!
Chad
TIA!
Chad
I can only speak for Exedy from personal experience. I've had them in 2 different cars(civic and neon) and I bought another Exedy to put in my daily driver this summer. Excellent products.
Just read the write up that got posted. Did you notice a big difference in your ability to start out in 1st gear meaning did you notice you had to rev the car up more for a smoother start? Looking at purchasing an Exedy Stage 1 clutch with a Fidanza 7lb racing flywheel.
sesi
10-01-2015 02:03 PM
ThatGuy913
09-28-2015 05:35 PM
beanhead
09-24-2015 12:04 PM
powman02
09-15-2015 07:38 PM
Klame9420
09-07-2015 10:03 PM
