DIY Wheel Repair
TRUST me! I'm Idiot Proof!
Rep Power: 165 DIY Wheel Repair
Picked these wheels up cheap on Craigslist. All the wheels had some curb rash on them. One in particular looks like somebody tried to jack the center cap with a pry bar:
Other shots of wheels before finishing:
First begin by rough sanding out the worst with 100 grit. A stiff sponge works great as a sanding block:
Follow up with 220, the finally 400 grit:
NEVER throw away old clothing!!
Ready for paint:
Now the tricky part. I used Loktite epoxy weld. Its a 2 part compound that you have to knead togther. You then have @ a 20min work time:
Clean the area to be repaired. Then rough form the paste into the contours of the wheel:
Let compound cure fully, usually about an hour. Start with 220 grit, then work your way up, being careful not to remove too much material. The idea here is to blend things smooth:
Now its time to paint. BEWARE!! Not all wheel paint will match. Some are more 'glittery' than others, or off shade, no matter what the cap looks like. Test in small area FIRST.
I did not want to repaint the whole wheel, as the scuffs were localized. I used cardboard cutouts of different shapes to allow only the areas needed, to get painted:
The finished product:
Although their not 'show' quality, they came out pretty dang nice.
Hopefully this will help somebody save some money!
I will follow this thread up with shots of them wrapped in Firestone Firehawk Wide Oval Indy 500, 205/55-R15 tires and mounted on my car.
Ready for paint:
Rep Power: 0 Re: DIY Wheel Repair
For those rims off of craigslist that is a clever way to patch em up.
P.S Oh yah, you gotta keep the old clothes. I use ripped crotch boxers for shop towels.
Those are the same rims I roll on by the way. This DIY would help me if I ever feel like taking a shortcut and hopping a curb. Good write up!
BootyDo
07-07-2015 06:06 AM
Causemo
07-05-2015 06:42 AM
