ATF Questions
ATF Questions
what is the proper procedure for checking the ATF level?....warm? cold? engine running? engine off?....i have checked it with the engine idling and with the engine off and i basically get the same level/result so does it matter?
and when you change the fluid is it just a simple drain and fill? or is there more to it then that? how much fluid does it take after i drain it? i dont think simply removing the drain plug would get all the fluid out?
Person
1 Post
Rep Power: 175 Re: ATF Questions
Check idling. Empty tranny takes about 6 quarts. Drain takes about two since it doesn't completely empty. You have to take out exactly what you put back in. I fill old milk gallons with the old fluid and then fill other milk gallons with the new fluid and put back just more than what was taken out. Good way to check if you have enough fluid is if you shift into drive and you clutch catches. The car should move on its own, if not it's low on fluid.
1 Post
Rep Power: 328 Re: ATF Questions
when you change ur ATF, u will only be able to take 3qt out. your total ATF capacity is 9qts.
Rep Power: 787 Re: ATF Questions
make sure you run the car moderately at least 30 mins. when the engine is warmed up, the trans is nowhere near full warmup. park on a level surface, cycle thru the gears, then put it in P and check the fluid level a few times. you have to be very fast putting in and pulling out the dipstick like less than a second to get a good reading. oil line should be at the top of the hash marks.
martinsmartin
08-15-2015 07:34 PM
Q-Bert
07-19-2015 09:09 PM
07-12-2015 11:54 AM
