Timing Belt + General Maint Questions
my 05 civic has 200,000 kilometers on it....it runs perfect and is mainly driven by my wife so it is driven easily and not abused in any way....
i keep it very well maintained on my own....the timing belt was done last at 104,000 so im due for a timing belt replacement again i assume....im wondering what else i should have done at the same time?....should i be replacing the timing belt tensioner or water pump or both?
i have done timing belts in the past on my own but this one looks very complicated compared to others i have done....so i will probably just take it to a local shop....any other advice?
Re: Timing Belt + General Maint Questions
Whachya lookin at?
Rep Power: 288 Re: Timing Belt + General Maint Questions
Timing belt, water pump, tensioner, crank + cam seals should just about cover all the majors.. Oh yes at that mileage I would also look into replacing the crankshaft pulley.
Live for the Twisties
Rep Power: 260 Re: Timing Belt + General Maint Questions
The water pump and tensioner are preventative measures, they might last for two changes, but they might not and it's a pain changing them so do it when your already down there.
TRUST me! I'm Idiot Proof!
Rep Power: 165 Re: Timing Belt + General Maint Questions
I say change/replace everything you can afford...MTF, oil, plugs, plug seals, crank seal, (cam seal's tricky imo), all belts, tensioner, water pump, valve cover gasket...hmm what else..
Anyway, study first THIS DIY on a timing belt change. Then follow it and nike that ****! If you run into trouble, you know where to find help...
i have been reading a bit more and it seems honda recommends timing belt every 90,000 miles is this true?....i thought it was 60,000 miles?....i have about 60,000 miles on the belt now....can i leave it longer?
Rep Power: 160 Re: Timing Belt + General Maint Questions
If you think your conditions are more Harsh, then inspect it, change if needed at 60k
Whachya lookin at?
7th gen civics are 100k according to the manual. I'd wait until it was due, I pulled mine at 140k and it looked brand new... I'm not guaranteeing yours will too though.
also....when removing the crank pulley bolt can you not just put the car in gear and get somebody to hold the brakes on?....wont that stop the crank from turning?
what size socket is needed for the pulley bolt?
Rep Power: 0 Re: Timing Belt + General Maint Questions
He is saying 100k miles. And there is a special tool required to remove the crank pulley. I made one lol. You might be able to bump the ignition just make sure you have it wedged properly so you don't damage anything and maybe pull the relay to the fuel pump so the car doesn't start.
thanks for all the help....i will buy the tool and i also thought about bringing it to a shop close by and having them loosen the nut and just tighten it up 50% or something to get me home....then i can remove it easier myself....
so my final question would be....how long should i expect (or how long would you guys think) i am safe to continue driving this car without timing belt, or tensioner, or water pump failure?
the timing belt was replaced at 60,000 miles and nothing else just the belt....i am now about 120,000 miles....i was going to do this job soon until i found out the belt lasts alot longer than i thought so i might leave it a bit longer if i can....i guess i changed it too soon last time....
Rep Power: 183 Re: Timing Belt + General Maint Questions
I recommend R2ing the timing belt water pump and tensioner. The crank pulleys don't go bad!
...Oh and the special too for removing the crank pulley is called a impact wrench! lol
Seriously you don't need any special tool for it.
Whachya lookin at?
I wouldnt run a harmonic balancer for a huge amount of miles. Also, how many times have you removed the crank pulley? The special tool is a MUST. Change the belt once it reaches 100 miles or whatever your manual says.
^I have changed 3 Honda timing belts using no special tools, just an impact wrench to get the crank pulley nut off and a torque wrench to put it back on. that is all that is needed for the crank pulley. If you want to go waste your money and time then go buy a special tool.
Mikey: You may not need to change it right away, but I would inspect it for cracking or separating at the very least. And if the manual says it's due then I would do it.
Whachya lookin at?
Ok.
Good luck getting that bolt off................ I hope you have access to a huge impact gun because MANY members on here have run into huge problems with that. Running out to the store to find a 30 dollar tool sucks royal *** especially when most places dont carry it. You want to have that in your hands before you even start the job... I mean sometimes they come off easy and sometimes they don't, for 30 bucks I'd rather be prepared.
The DIY (explain well why you need the tool):
https://www.civicforums.com/forums/3...t-diy-2-a.html
The Thought:
https://www.civicforums.com/forums/1...ey-holder.html
The Outcome:
https://www.civicforums.com/forums/1...ming-belt.html
More:
https://www.civicforums.com/forums/7...-question.html
There are tons more, I just don`t feel like searching.
The Thought:
The Outcome:
More:
Two things
First, the only method approved by Honda to remove the crank bolt is a breaker bar with the special tool, thats even the method the techs who have access to 1000ft lbs impacts use.
Second, the average impact won't remove the crank bolt. The few members who aren't techs and actually have air tools or an electric impact will still be out of luck without the tool, because average 550ft lb impacts are nothing in this battle. typically a 1000ft lb++ impact is needed.
thanks for all the replies....
i didnt mean for this thread to be a battle over "the tool"....that really is not my question....if i choose to do this job myself then i WILL buy the tool and have it before i start the job....
my question right now is....how long should i wait....or how long can i wait before i change the belt, tensioner, and water pump?....keeping in mind what i said a few posts earlier....
Like tbohar said, their good per the manual for 100k MILES...so your pump, tensioner, ect is 20k overdue.
AND...use the tool. I suppose locking the gear could work, but id rather not put that kinda stress on my tranny. Another method I ran across involved chaining the pulley to the frame...
IMHO, its a gamble either way. Wait, save money and risk major failure...possibly...OR...just get er done now and have peace of mind.
So stop dithering and get busy!!
PS: change the ALL the belts AGAIN...do NOT try to re-use one...for all the work involved it aint worth it.
Last edited by BobDobolina; 03-27-2011 at 09:47 AM. Reason: noticed something else
ehhh...whatever. Spin it around and if its loose and noisy, replace it. Its all just a guideline...Whens the last time you had a set of tires for the advertised ...oh idunno...60,000k mile tread life?? much shorter, huh?
yes i agree with you about the tires....however you cant compare that to hondas maintanance schedules....i dont think a large reputable company like honda would mislead all of their customers with shabby info or every single person would be snapping their timing belt....
Received 1,440 Likes
Rep Power: 338 Re: Timing Belt + General Maint Questions
hehehe!
search around to see how many people just recently have had bent valves
Like Bobdobolina said, go get busy - enough mental masturbation. all the info have already been laid here
yes i believe you....but those are probably people who let the belt go WAY PAST the recommended time to change it....you are missing my point....what im saying is honda would not recommend 90,000 miles if there was a good chance it would snap at 80,000....im sure they would make sure they cover themselves....
TB is still good up to 110k, that is true.
water pump there were several that found it was pristine, but to do that job again, well, they just changed it anyway.
do you know that normal estimates are for 8 hour job?
