Sponsored by:
Sponsored by: DashLynx
transmission fluid change
Old 03-14-2011
Sedans > Coupes
Brian1037's Avatar
Brian1037 is a jewel in the roughBrian1037 is a jewel in the roughBrian1037 is a jewel in the rough
a lot of people have said to do the 1/3rd fill/drain method, however this guide doesn't. https://www.civicforums.com/forums/1...placement.html
so which is it? is it safe to follow the guide or should i really do 1/3rd drain/fill?
Brian1037 is offline
Old 03-14-2011
Re: transmission fluid change
its always better to do 1/3rd otherwise you are putting too much new fluid in that can cause problems.
gearbox is offline
Old 03-14-2011
Too Tall's Avatar
Too Tall will become famous soon enoughToo Tall will become famous soon enough
Don't confuse oil change procedures of manual and automatic transmissions. I've never changed Honda manual tranny fluid, but I assume it has a drain plug that drains all the fluid out. Auto trannies drain about 1/3 total oil capacity out of the pan because the rest remains in the torque converter and oil cooler.
Too Tall is offline
Old 03-14-2011
yeah youre right, manual trans only has 1.7 qts total capacity and doing a single fluid change replaces almost all of it (1.6 qts).
gearbox is offline
Old 03-15-2011
Sedans > Coupes
Brian1037's Avatar
so what i'm understanding is that auto trannies require the 1/3rd fill/drain because you have no choice, and manual trannies are ok to drain cause .1 quarts will always remain inside?
Old 03-15-2011
yeah autos have a 9qt capacity but draining the fluid only removes 3 qt.
gearbox is offline
Old 03-15-2011
Sedans > Coupes
Brian1037's Avatar
perfect, thanks!
Old 03-15-2011
Too Tall's Avatar
Consider that an estimate. I think the 07 Civic auto tranny drains 2.3 qts on one oil pan drain.
Check your oil level before you drain, and measure the amount of oil you drain out, run the tranny through the gears with the tires in the air before trying to drive to ensure air bubbles don't get to the clutches.
Too Tall is offline
Old 05-04-2013
Civic_2008-4dr's Avatar
Civic_2008-4dr is an unknown quantity at this point
5/4/2013
I just did my first drain and fill (2.75 quarts). It was a real challenge getting the drain plug loose! I thought I was going to either break the plug or the ratchet! All went well after the huge breaking sound. I jacked up the drivers side first. Seems like you may get a bit more fluid out that way. The manual indicates a 2.5 quart fill although I measured 2.75 quarts. It's at the top of the fill range when it's hot so I figure that's a good thing! As far as I know, this is the first transmission fluid change and I had 40,500 miles on the car.I bought the car in nov 2011 and it had 8,700 miles on it. Hopefully if I keep the fluids maintained, this car will last a good long time. Oh, I did use the newly recommended Honda Genuine DW-1 which replaced the Z-1 fluid. I also use the mobil1 extended performance fully synthetic motor oil.
Civic_2008-4dr is offline
Old 05-05-2013
mikey1's Avatar
Originally Posted by Civic_2008-4dr
5/4/2013
i just changed mine yesterday too,
i removed the passenger side front wheel, then i used a whole bunch of 3/8 extensions so i could use my breaker bar outside the wheel well,
i used a jackstand to support the end of the entensions then used my breaker bar to loosen, this made it very simple, kind of the same procedure used to remove the crank pulley bolt,
made it easy to use my torque wrench when tightening the bolt too,
while it was draining i lowered the passenger side of the car until the brake rotor was almost touching the floor, this helped to drain out some additional fluid
mikey1 is offline
Old 06-30-2013
ke6pls2's Avatar
ke6pls2 is an unknown quantity at this point
From a Honda fluid tech who is a friend...my 2001 Civic LX has the following done for a flush. Drain the fluid out of the tranny from loosening the plug on the passenger side. Poor ATF fluid (any standard type)in the dipstick hole using the same amount as drained . Drive for about 3-4 miles at all speeds and shifting through all gears at their perspective speeds. Drain while hot. Then of course reinsert plug and fill with Honda ATF. Done!
ke6pls2 is offline
GolNat
Suspension DIY
05-12-2022 06:49 AM
mattdoc
03-14-2017 12:10 PM
mrohitredd
05-28-2015 10:03 AM
cruisers10
05-12-2015 10:46 PM
bsmiley
04-27-2015 01:27 PM
Quick Reply: transmission fluid change
