Driver Side low beam isn't working. Fuses seem fine.
Rep Power: 0 Driver Side low beam isn't working. Fuses seem fine.
Worked on my audio system and after reconnecting the battery, the driver side low beams do not turn on. First time this has happen, I work on my stereo system a lot and always disconnect the negative terminal battery. Checked the fuses and they seem to be fine. Is there anything else I should look at it before purchasing a new set of low beams?
Live for the Twisties
Rep Power: 260 Re: Driver Side low beam isn't working. Fuses seem fine.
Have you tried switching the passenger side bulb over to the drivers side headlight, that would tell you if its the bulb or something more major.
ashlava71
05-16-2015 12:54 PM
intensity
05-12-2015 10:43 PM
Supramk3
05-11-2015 07:55 PM
